Fuel change at the track?
v8ter
Typing...
EL PASO , TX
MUSTANG GT 2015 50TH
Anyone done fuel change at the track? Can you share what adapter and process you use to do this?
esacteksab
CO & KS
2015 Mustang GT
With the stock rails, you could do something like this https://www.amazon.com/dp/B00VU5X1S2/_encoding=UTF8?coliid=I395EFRDXET4GX&colid=3TI8NVFCJX0V9
When you want to swap fuel, pull the plug, put in a hose that feeds into a jug.
If you have a return style fuel system, you could use the return line. Depending on who tuned it and how it's tuned, you could have a tune that runs the fuel pump long enough to drain the tank..but with something like an SCT, the length to do this would suck and would require a battery charger for the duration of the application/swapping of the tunes.
Just my $.03 cents.
RockStang
AA county MD
Joe
2016 GT Whippled
Jpc sells a kit. I've used it several times at the track. It's uses a similar adapter to what esac posted. Install in at the fuel rail, start the car and the fuel starts dumping out. I just run it until it dies.
kcc0521
Falls Church VA
Bo
2015 Black GT PP
I bought everything like JPC kit but it cost almost as much. I would just go with JPC kit. So far I have been too lazy to use it.
