FRPP track pack alignment advice
Discussion in 'Suspension, Brakes & Chassis' started by Blauplow, Oct 10, 2017.
  1. Blauplow
    Blauplow Active Member
    Vehicle(s):
    2015 GT
    Jan 26, 2017
    Bay Area
    33
    #1 Blauplow, Oct 10, 2017
    I got the track pack installed a week ago so its time for an alignment
    I also installed the Max motorsports caster camber plates
    Application is for aggressive street driving only, not dd or tracked
    Im thinking of having it aligned to the following based on reading all the threads I could find
    Front camber -2.0
    Toe 0.0
    Rear camber -1.5
    Toe 0.25
    would the Gurus agree or suggest different settings?
    or people who have had the same kit what did you ultimately end up with
  2. Glex25
    Glex25 Well-Known Member
    Vehicle(s):
    2016 GT PP
    Oct 25, 2015
    North Jersey
    255
    89
    0   0   0
    I went with the specs Ford Racing suggested on their installation manual
  3. lilgdad
    lilgdad Well-Known Member
    Vehicle(s):
    2015 Mustang GT PP
    Jul 22, 2016
    Cbus, Ohio
    66
    Hmmm... PP spec is frnt -1.03 camber, rear -1.5, track pack spec according to Ford is frnt -1.55 rear -1.98. i would say stay with what Ford spec is either way.
  4. Bluemustang
    Bluemustang Well-Known Member
    First Name:
    Vehicle(s):
    2015 Mustang Base GT
    Nov 6, 2015
    3,149
    1,375
    Occupation:
    Financial
    0   0   0
    The Ford Racing performance alignment is sharper steering wise and will help you corner better but with a bit more tire wear. I suggest going to the PP spec rather than the Performance spec, the car will behave better on the street manners.
    I am using about -1.8 on front and rear and it corners very well and the steering is very responsive, almost too responsive on the highway. It almost turns bends on the highway just thinking about it- without much conscious effort on the steering wheel. But going straight on the highway I now have to pay more attention to the steering wheel but it's so responsive to road conditions.
  5. Grintch
    Grintch Well-Known Member
    Vehicle(s):
    2015 GT PP
    Nov 7, 2014
    Hunstville
    1,585
    553
    0   0   0
    Maybe on the street.
    Front tires won't last long on the track without more camber.
    I run as much camber as I can get, after blistering a RF MPSS at my first track day with the FR settings. At - 2.5 F, - 2 R with my current setup. Works fine on the street, but a back injury has kept me off the track.
  6. Eritas
    Eritas Well-Known Member
    Vehicle(s):
    Aug 30, 2017
    938
    397
    0   0   0
    No reason for -2* up front if it's never going to a track. You'll just burn up the inside front tire for no reason. I'd stick with the factory camber.
  7. OP
    Blauplow
    Vehicle(s):
    2015 GT
    Jan 26, 2017
    Bay Area
    33
    Sounds like I'm just going to go
    Front -1.5
    Rear -2
  8. Grintch
    Vehicle(s):
    2015 GT PP
    Nov 7, 2014
    Hunstville
    1,585
    553
    0   0   0
    I would do at least - 2 all around. You bought camber plates, might as well get some use out of them.
    The front has a worse camber curve than the rear (really needs more static camber to compensate), and - 2 camber in the front is not going to burn up the fronts anymore than - 2 will the rear. Plus camber is usually a small contributor to tire wear.
    The only reason Ford Racing doesn't recommend more at the front is that there is no adjustment on the front with the stock & track pack hardware. The gain over stock is just what you get from lowering the car. They really should add some camber bolts to the package.
  9. JamesinLittleSilver
    JamesinLittleSilver Well-Known Member
    Vehicle(s):
    2015 Ruby Red Ecoboost Premium
    Nov 10, 2015
    Little Silver, NJ
    375
    74
    0   0   0
    I had the dealer set it up as FP suggested.
  10. Eritas
    Vehicle(s):
    Aug 30, 2017
    938
    397
    0   0   0
    :confused:
    The front struts has virtually zero camber gain. There really is no gain in camber from lowering the car.
    Ford Racing recommends -1.75* for the GT350s front which isn't attainable without modifying the two lower strut bolts. The reason the front recommendation is so low on the GT for STREET use is you don't need -2* on the front of a STREET-driven car.
  11. BMR Tech
    BMR Tech Well-Known Member
    Gold Sponsor
    First Name:
    Dion
    Vehicle(s):
    Sep 4, 2014
    Tampa, FL
    5,109
    3,575
    0   0   0
    OP, feel free to shoot me an email, [email protected]
    I've got some settings / set up info I can send to you based on working with similar packages over the years.
  12. Grintch
    Vehicle(s):
    2015 GT PP
    Nov 7, 2014
    Hunstville
    1,585
    553
    0   0   0
    You gain about 0.2 (negative) lowering the front an inch. You WANT to gain (negative) camber as the tire is loaded (suspension compresses), that is why you need more static camber with a strut suspension. Thus you actually need more in front than with the multilink rear, that has a better camber curve (more dynamic camber gain).
    You don't need any camber driving your kids to school, driving the under posted speed limit. You do driving hard through the curves. Given the OP bought the Track Pack, and camber plates, and said he wanted to drive hard. I figure he needs a performance alignment.
Loading...
Share This Page
