Front Tire Inner Edge Scallopping
NS15GT
Nova Scotia
2015 GT Magnetic Metallic
Hello all,
Reaching out for some assistance on solving this issue on my car. Have been looking to try and find a definitive answer with no luck. So here is where things stand, changed to a 285/35 tire up front on LMR R355 wheels from the stock 255/40 and lowered on BMR performance springs. I had the alignment checked before switching to the current set up as I had noticed the same issue on the previous tires. At that time was running the stock PP wheels with a 25 mm spacer all around. Thought the problem was related to the spacers and when alignment came back in spec figured that was that. Started to notice more tire noise than usual and found the problem hadn't gone away. Most recent inspection didn't reveal any issues in the suspension or at least I wasn't told of any.
Has anyone with a similar set up had the same problem? Can lowering cause uneven tire wear while still within factory spec for alignment? The tires have a lot of life left yet so would like to sort this out before they have to get replaced and the same cycle happens again.
Any insight would be appreciated.
Thanks
cerbomark
TN
20 GT PP2. 21 Mach1 (Sold)
I d be looking at the quality of the alignment again. Toe especially.
NS15GT
NS15GT
Nova Scotia
That's kind of what I was thinking but figured there might be something that hadn't occurred to me to check. Thanks.
GrabberBargeCaptain
CA
Can you post your alignment sheet?
NS15GT
NS15GT
Nova Scotia
Unfortunately no as now I can't find the damn thing.
skinnyb
Knoxville TN
Alex
21 Mach 1. FJG, Tremec
S550 Mustangs are known to eat the inner edge on the front tires... Even with stock wheels and tires and factory alignment. Toe is critical for sure... Doesn't take much at all, just because its in the "green" doesn't mean its not out just enough to cause a problem...
NS15GT
NS15GT
Nova Scotia
I'll get the alignment checked during safety inspection this month. If it's good just have to chalk it up to sometimes you gotta pay to play. Thanks.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Toe out will cause inner tire wear.
