Front suspension lower on one side
stangjp
montreal
2016 mustang gt
I have a 2019 mustang i'm on my 3rd set of spring on it and every time it look like one side sit lower than the other. I dont know if it's lower or the other side is higner. What can cause this ??
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Stock rubber bushings are very "sticky". If you don't loosen them and re-tighten at the natural ride height after you change springs, then its very common for the car to be too high at one or more corners. This is called 'clocking the bushings'. Its a required step to get the car to settle after you've changed ride height.
Did you do that?
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
stangjp
stangjp
montreal
2016 mustang gt
Did you do that?
No i didn't do that. Wich bolt exactly i have to re-tighten on the front because it's third set of spring i put and it's always on the passenger side that looks higher
NightmareMoon
If you do a search for Clock Bushings there is a Steeda or BMR diagram which points out the specific bushings you need to loosen up and retorque after they’ve been allowed to reorient themselves.
Its basically every pivot point where there is a rubber bushing and not a solid bearing. Sorry I dont have the link right now.
BmacIL
Enginerd
Naperville, IL
I posted it above...
stangjp
stangjp
montreal
2016 mustang gt
Ok thanks guys i'm gone try that
808muscle
Lahaina HI
2016 GT Premium Whipple, 2006 GT Blown and cammed
Clocking is very important. Just had mine done a few weeks ago after lowering. It made a huge difference in how the car rides and grips the road. Tech even saw the bushings turn as he loosened the pivot points.
NightmareMoon
I wont admit to knowing it by feel, but yeah you can see them turn when they are loose enough, and the car will settle once all the binding joints are addressed (if its on an alignment rack or allowed to roll). If you still have a significant ride height difference, then something else is contributing.
808muscle
Lahaina HI
The difference in feel was big enough to notice after the clocking and alignment for me. Ride height is even all around the car as well. I was very impressed with the improvement it made on my car. Of course every car is different.
Cardude99
Phoenix, AZ
Sam
2018 Ecoboost
So when I go to the alignment shop and ask them to clock the bushings, will they know what I'm talking about? Is this a common request or is it something that I will have to explain? Also do you have to loosen the bushings on all 4 wheels at once then tighten or just one wheel at a time? Finally how may bushings per wheel is there to loosen?
NightmareMoon
Post #52 in the thread that BmacIL linked has a diagram. Post #1 is BMR explaining what to do.
I’d bring the diagram from post #52 and torque specs from the sticky thread at the top of the suspension forum to the alignment place, as there is a good chance that will help.
BmacIL
Enginerd
Naperville, IL
Most shops will not know what you're talking about. You will need to show them the pictures from the above thread. It is advisable to loosen the bolts on all four corners, jounce the front and rear of the car, and then retorque.
stangjp
stangjp
montreal
2016 mustang gt
I try to clock all the bushings but the problem still there. The driver side looks to be lower than the passenger side. I really don't know what to do now.
stangjp
stangjp
montreal
2016 mustang gt
I have 2 of my friend with the same suspension (vogtland sport 1inch drop) and when i look my car it really seems to be the front driver side to be the problem.
