Forum promo code Steeda?
B_E_N
québec, canada
Benoît
2020 pp2
thanks for your quick reply, can i get the promo code for steeda official site?
tj@steeda
Timothy
Haulin’ator
Montréal, Québec
Daniel
2020 Mustang GT Premium
Hi guys,
I’m looking to place an order with you online and was hoping to get a discount code as well, please. 😉
Steve68Cougar
KS
'68 Cougar, '08 Mustang Bullitt, '18 Mustang RS2
If you have a discount code available, that would be great. I'm looking at ordering camber plates. I've got an '18 Roush with coilovers, so does that mean the coilover version is necessary? The wording in the description makes it sound like both versions are compatible with the KW/Roush setup. I don't want to order the wrong thing. Thanks!
tj@steeda
Timothy
Sorry for the delay - I had to get confirmation from our tech team
KW has 2 types of front struts for these cars, a conventional coil over and a “direct fit” coil over
The V-3 kit falls under the direct fit style, it will use our standard 555-8139 kit.
You will have to use the factory upper spring seat when assembling this kit.
which kit do you have?
Let me know!
TJ
Steve68Cougar
KS
Let me know!
TJ
I've got the Roush single adjustable kit, which I believe is (essentially) the same as the KW V1 series. My initial thought was that it uses the same setup as factory because there is no mention of having to change the upper mount out when installing the coilover kit. What you're saying would be consistent with that. Thanks for the info.
Jackthewack
Austin Texas
Mason
2019 GT mt82 magnetic
Any discount codes going on right now?
mikeD4V
MD
15 GT
Can I have the forum discount code for an order? Looking to order S550 Front Control Arms (Lateral and Tension Links w/ Bearings) PN 555-4909 and S550 Stainless Braided Hose Front & Rear Brake Lines PN 555-6027 ASAP. Thanks.
Jwod1993
Pennsylvania
2017 Mustang GT PP
Hi Guys,
Any Steeda discount codes going on right now? Looking to buy a 2018+ manifold and SCT tuner with lifetime tuning services from you guys. Please let me know!
Thanks,
Jake
Jackyboy
Tennessee
Jack
2020 mustang gt, 2014 focus se
Looking to see if i can get a discount code for forum members. Wanting to buy some kw v3s, steeda jacking rails, and steeda clutch spring from your website.
Also i am not sure i understand the difference between the three different jacking rails. If you have the time can you please point me to a resource that compares the three?
Thanks,
Jack
Inconsis10t
Dallas, TX
David
2019 Bullitt K6137
Any current Promo Code going on right now?
avy15
Alex
2017 Ford Mustang GT Premium
Hey Steeda! Any discount codes I can use on my cart?
J. Kidd
Suffield, CT
2016 Shelby GT350 / Track Pack
I'm looking (for forum discount code) as well....or any upcoming sales codes.
SmokinAces
San Antonio
Eddie
2020 GT350
Hey tj@steeda, looking at the G trac brace and rear cradle brace. Wondering if a discount code is available at this time. Thnx for your time and effort.
Sham_POW
Charlotte, NC
Jon
2020 Mustang GT
Hi tj@steeda. I'm pulling the trigger on the rest of my suspension in a couple of weeks and was wondering if I could get one of those discount codes. I've been waffling a bit on which parts, but since I already have the Stop-the-hop kit I figure I may as well go all-in on Steeda for this autocross season.
Rear camber adjustment kit 555-4126
Camber plates 555-8139
Front sway bar end links 555-1040
Front sway bar 555-1015
Magneride dual rate ultimate handling springs 555-8243
I could use a sticker/magnet or two to represent also. :D
