DUNDEM
ATM for the win! Worth the money! I’m runjjng the stock tune in 99 degree weather with night and day difference. Stock IC is immediately heat soaked before shifting in to second. I was on the fence with stock location MAP style or larger ETS style and this made the most senses. Glad I got it! No matter what though you’re not enjoying your car without any IC must have mod.Guys, use my dyno as a baseline ONLY. I'm running a unique setup that pretty much nobody else is here, at least not with the FP tune. Recall that I am running a manual trans with 3.73 ring and pinion.
My dyno numbers will be a bit higher than most due to the combination of short gearing AND manual trans. So I'd expect auto's and 3.31 manuals to be slightly lower to the wheels power due to higher gearing.
Gearing absolutely affects power to the wheels. It's a torque multiplier . Power is a ratio of torque and RPM.
By the way, I flashed back to stock just out of sheer morbid curiosity to see how the stock tune felt with the ATM inter cooler and was really surprised at how little fade there was on the top end. Power actually felt flat across most of the range. The ATM FMIC works very well with the stock turbo. It provides cooling roughly on par with the big full sized FMIC's but without the necessary volume and with lower pressure drop. For those still on the fence about the FP Tune who are also running the stock FMIC, first upgrade you FMIC and drive the car for a month. It's pretty good overall and more what I expected it to be from the factory. Then upgrade to the FP tune and it will be really good. Finally after you've hit 36k, assuming the car is still mechanically sound, step up to the Livernois 91 tune.
A lot of the FP guys run Livernoise tunes on their own cars. Really the big difference in tuning is the fact that FP is still limited in what they can do by emissions where Livernoise isn't, so there's some decent gains on the top end which still fades even with the FP tune after about 5800.
Now for context, even though you will loose 50HP on the FP tune from 5800 RPM to 6500 RPM, your still up about an average of 75 hp from the stock tune, so FP was still able to provide some good, solid gains. The only real difference in power curve with Livernois and FP is that Livernois holds torque better, you don't go from a 30 degree drop to 45 degree drop in torque starting at 5800 RPM. So with the Livernois 91 you hold near the peak power all the way out to 6500. Your only down about 10~15 hp from 6100 to 6500 instead of being down 50 HP from 5800 to 6500. BUT, if you have emissions you will need to swap back to stock once a year or once every other year for a couple weeks to get it passed, but it's rather easy to do, 5 minutes so not a big deal.
