Fitment Help Needed
BigBrian27
Pennsylvania
Brian
2021 Mustang GT PP1
Hello all,
Long story short I got a great deal on a set of wheels and I'd like to put them on my 2021 GT PP1.
Wheels are MRR M600. Fronts are 19x11 +24 and the rears are 19x11.5 +52
My car is lowered on Steeda minimum drop springs (1/2" drop all around).
Current tire sizes are 255/40/19 front and 275/40/19 rear.
I'd like to run a 285/35/19 front and 305/35/19 rear.
From my research it looks like the rear should fit no problem. The front however, I might need to run camber plates?
Has anyone run a similar setup and if so, what did you have to do?
NightmareMoon
2016 Mustang GT PP w/ Voodoo
You can dial in the front poke better with camber plates, yes
those sizes will be ok. The 285 will be stretched on an 11 but as long as the tire is something like an MPSS and not a Nitto it will look fine (rim protector feature on the MPSS helps).
BigBrian27
BigBrian27
Pennsylvania
Brian
2021 Mustang GT PP1
I was planning on going with Continental ExtremeContact Sport 02 tires.
NHMach1
California
Nate
2020 Mustang GT
Conti 02s 295/35 or 305/35 front. I run 295/35/19 front and 305/35 rear on a 19x10.5 front and 19x11 rear. Best tire I’ve had!
NightmareMoon
I think those have rim protectors, or the internet says most sizes do
NightmareMoon
According to Continentals site, neither size has rim protectors.
welp, there you go. Not sure how it will look and you may scratch a wheel rim more easily. They'll still fit.
BigBrian27
BigBrian27
Pennsylvania
Brian
2021 Mustang GT PP1
Not too worried about hitting curbs. Where I live I rarely park along curbs.
BigBrian27
BigBrian27
Pennsylvania
Brian
2021 Mustang GT PP1
I'm afraid that a 295 up front won't fit.
Bob Lob Law
Jeff
'22 GT 401A ESS A10
The Conti ecs02 has a LOT more of a rim protection than the Indy 500s! At least in 285/35 19 and 325/30 19.
NightmareMoon
Why? Plenty people have reported using 19x11 and 305 all around.
315 here :)
yeah with that offset and wheel size, and the camber plates, you can definitely fit a 295. An 11" wheel closest in width to a 305 tire, so 305 is the standard fit but a front 305/35/19 won't do your fender liners any favors, most run a 305/30R19 not a 305/35 for the front.
Nothing particularly wrong with a 285, but the 295 is worth considering IMHO. I can't say who runs a 295/35 though.
BigBrian27
BigBrian27
Pennsylvania
Brian
2021 Mustang GT PP1
315 here :)
I would think a 305/30 would make for a harsh ride compared to a 285/35 or a 295/35.
I'd definitely consider a 295/35 if it can fit.
