First time at track with new 15 not happy
RUBYREDGT
Omaha
2015 Mustang GT
I was a bit disapointed. My pony came with 235/50/18 pirellis from the factory.
Kearney Raceway Park Density Altitude: 3906 feet
Relative Density: 89.06 %
2105 Elevation
Read more: http://www.dragtimes.com/da-density-altitude-calculator.php?track=94#ixzz3e60uzFeM
60ft 2.33
330 6.069
1/8 9.061
MPH 83.33
1000 11.56
1/4 13.670
mph 107.81
Any suggestions? My mph seemed consistant at 107 seems low?
I tried launch control on/off. I tried traction control and advance control on/off. I tried from idle and slipping clutch.
Are drag radials the solution? Any advice is welcome.
Mods were FR Xpipe and BAMA 93 race tune. M6 3.31's:tsk:
Grimace427
NoVA
2011 Mustang 5.0
Your 60' is definitely holding back your ET, but your low MPH is really being killed by the DA. I'd datalog that tune and send it back to BAMA for revisions.
RUBYREDGT
Omaha
2015 Mustang GT
Yea I logged the tune the rep from bama said it was dialed in correctly already. They aren't very good with communication. I know some tires will help. I am a bit nervious about the half shafts but would liek to order NT05rs.
RUBYREDGT
Omaha
2015 Mustang GT
Here is the correct time with the DA site.
13.017 @ 113.064 MPH
Grimace427
NoVA
2011 Mustang 5.0
Post your datalog here and I'll give it a look. I'm not a professional tuner but I've learned quite a bit reading logs.
113mph is pretty good for MPH. You need to get your 60' under 2.0 and you'll be in the 12's, corrected for DA. Nearly 4,000 feet is really bad air.
RUBYREDGT
Omaha
2015 Mustang GT
Yea it was 80 some percent humidity that day. What is your take on tire suggestion? Street tire replacement with a bit more bit or DR's?
Grimace427
NoVA
2011 Mustang 5.0
If you're going to hit the strip more often I'd upgrade the axle shafts and get 17" slicks or radials on a dedicated drag setup. That's the only way you'll get the maximum out of the car. With street tires you can certainly improve your launch technique but you won't put up awesome numbers on the board.
I've done a 1.88 60' on OEM Pirelli 255 summer tires with my 2011 5.0 but that was a top level prepped track(MIR) and I haven't been able to match it. I can do mid 1.9x with my current Continental DW 275 tires on somewhat prepped tracks but it is very inconsistent. Street tires just don't work very well at the drag strip.
RUBYREDGT
Omaha
2015 Mustang GT
Hmm heard anything about Toyo R888 or R1R?
RUBYREDGT
Omaha
2015 Mustang GT
What is a good summer performance occasional track tire?
bluebeastsrt
Oh boy
New Jersey
BigD
Ruby red 2019 GT Premium.
There really isn't a good compromise tire. Drag radials are made of a different more sticky compound then street tires. With a drag radial your sixty will most likely be in the 1.7 range. I had P-zeros on my 2011 Camaro SS and had no problem at all hitting consistent 1.9 sixtys. But that's as good as it gets on street tires.
RUBYREDGT
Omaha
2015 Mustang GT
Yea I guess I'm just lookign for something I can hit 1.8-1.9 consistantly and not break the halfshafts for now.
mdnt
Albuquerque
15GT/PP RubyRed
a 2.3 60' says it all, need to get down to 1.9-2 on street tires, if on DR then look for 1.6-1.8s
RUBYREDGT
Omaha
2015 Mustang GT
I don't think the 235's are capable of 1.9 or are they haha
