First Mods Done- Window, Headlight & Tail Light Tint Kit
Z_Rocks
S.W. Fla, USA
Import
The ports on the 5.2 are slightly larger than the ones on the 5.0l. We will be porting the manifold on the Whipple to match them up.
Since we'll be the first ones installing a Whipple on the new GT350 we're basically doing their R&D on this new platform.
Jared
Jared, doesn't this engine have too much compression ration to be blown?
LethalPerformance
LethalPerformance
Fl
2020 Shelby GT500 CFTP, 2021 Whipple'd F150
04Terminator
Humboldt County CA
Cindy
GT350 (sold); 04 Cobra (sold)
Clink
'14 Focus
Car looks great guys
Now please get that dealer sticker off the back!! :D
LethalPerformance
LethalPerformance
Fl
Hell no man. That sticker belongs there. Those are our boys and they take excellent care of us so we rep them as much as we can.
Rhumbline
DMV
2001 BMW M3
Not to be Negative Nancy, but isn't the point of lights, especially headlights, to be as bright as possible, not dim? I do get tinting the windows, up to a point, what with being in hot sunny Florida and all, but night's just as dark there as anywhere else.
LethalPerformance
LethalPerformance
Fl
It all comes down to personal preference.
In my opinion the darker lights look much better than they do without the tint. There's way more contrast now between the color of the car and the dark lenses.
Jared
gravedgr
Alpharetta, GA
Doug
2017 GT350
I guess the real question is - how much does the tint limit the light from the headlights? Don't they have specs on incoming/outgoing light reduction?
likeaboss
Baltimore, MD
2020 Corvette Z51
That's the fun of watching Lethal and Whipple figuring it out. Let them break stuff and then buy what they finally figure out is safe down the road.
Clink
'14 Focus
Ah I see well in that case I'd still remove it lol.
Not too many folks willing to do that, I wish I lived closer to you to check them out.
Voodooo
SE Michigan
Scott
Carroll Shelbys Soul Lives Under My GT350 Hood
The compression ratio of 12.0:1 will produce more power then a voodoo with a lower compression. The main concern will be the fuel octane, delivery and timing factors. A rule of thumb is a point of compression increase is about a 4% rise in power. But when boost is included the in mix the power increase is higher. For an example, if we had two voodoo 5.2l engines being exactly the same except for compression ratios.
Voodoo #1 9.0:1 say makes a naturally aspirated power of 463 hp
3 points of compression x 4% = 63 hp increase.
Voodoo #2 12.0:1 makes a naturally aspirated power of 526 hp
Adding boost to both engine will increase the power output. But adding boost to the 12.0:1 engine is going to still make more power as long as the timing can be controlled. Sometimes though adding boost or say NOS to a higher compression engine the gains are less then a lower compression engine. If all things being equal and the only difference is the base compression example being
9.0:1 compression boost of 25 psi may make 800 hp
12.0:1 compression boost of 25 psi may make 1000 hp.
Poisyn
Tampa
Tree Fiddy
Boosting effectively increases the already relatively high compression ratio. 12:1 is considered the safe limit for stock boosted cars, this is AFTER calculating the effective compression including PSI
You will always make more power by lowering compression and increasing PSI
Curious to see how much we can squeeze out of this without blowing the heads off!
Voodooo
SE Michigan
Scott
Having a lower compression on a boosted engine does not mean it will make more power. I know for a fact that the higher compression will make more power with all things being equal. You'll see. Don't believe me? Ask Sean Hyland.
Poisyn
Tampa
Tree Fiddy
I'm not talking about all things being equal, my reply wasn't even directed at you. Obviously it'll make more and that would be amazing in a perfect world lol but that's not what we're dealing with
Decrease in compression means more boost/power where it matters under full throttle
Also wouldn't be surprised to see them only running alcohol when they throw the whipple on there
