FI Interchiller Stage 2, Two Month Review
DougS550
Fishers, Indiana
Doug
It's been around two months since my FI Intetchiller Stage 2with CWA400 pump install, large condencer with fan, relays, wiring, connectors etc.
I would rate this install "Extensive" due to my previous mods I had to mod or remove, cutting, making braces/brackets, cuting the front crash bar for intetchiller, relays, wiring I had to make/modify/Weld a 2.5 gallon mishimoto tank. I had to modify tank extensively to fit behind my drivers side fender well area, dual horns, front cruise, crash medigation module etc, adding a large condenser and fan, replacing/adding connectors etc, removing my whipple H/E etc.
- Crusing with my A/C off and just the IC pump running in 87° f outside temp, my AIT2 stayed under 120°f, but I did not run my car hard.
- Crusing, stop and go traffic, WOT in 90°f with A/C on, interchiller on my AIT2 stayed around 60°f-70°f and the IC coolant to the whipple got as low as 30°f but normally stays around 40s°f range. Even after a dyno pull the tech put his hand on the top of the whipple and he said it was cold.
So far after weeding everything out, no issues. I never lose power due to heat soak under back to back WOT runs.
FYI. I went above and beyond on insulating the tank, hoses, lines etc to maximize cooling efficiency then some installs i seen on you tube.
