Feel any difference switching to a lighter setup?
West TX GT
Ian
2018 Royal Crimson GT
Just curious if any of you guys have had a noticeable difference other than more grip (if stickier tires) or if it isn't that noticeable. If any of you have also done a lightweight drive shaft which was more noticeable?
NightmareMoon
2016 Mustang GT PP w/ Voodoo
If you take off 5 or lore lbs it's noticeable, but a little difficult to describe. I feel it in the suspension and how the car responds to bumps more than I feel the low speed accel/decel
scoggy_doogan
2016 GT Premium
I really didn't notice a difference. I went from the stock 18" wheel and tire at 54 lbs to a set of MRR M350 and conti tires at 50 lbs. I notice the increase in grip due to the larger tires and better compound more than anything.
Moddiction
Mooresville, NC
2016 Mustang GT PP
I'm hoping I will feel a big difference. I'm going from stoke pp wheels to 19" forgestar cf5v's. should be about 8- 10 lbs less per wheel. In addition rear tir s about .8" smaller diameter so it should change effective gearing about 4% shorter.
Eisman
Petawawa Ontario
Mustang.... Duhhhh
I'm hoping for the same thing. In a couple months, I'll be switching to new wheels with a shorter tire.
The lower rotating mass will improve acceleration, braking, suspension reaction, and overall handling.
Moddiction
Mooresville, NC
2016 Mustang GT PP
Yeah it should definitely help! I am thinking of going with some Baer 2 piece front rotors as well. That knocks off another 10 lbs a wheel or something I believe.
Eisman
Petawawa Ontario
Mustang.... Duhhhh
Nice... I just wish that new rotors weren't so expensive. My new wheels and tires are going to eat up my car funds for this year. Worth it though.
ghostnote
PR
Mustang GT 2015
unsprung rotating mass (eg tires and wheels) gives the most bang for buck in terms of weight reduction.
i went from gtpp and pzeros to m350 and mpss. aside from the difference in grip (mpss are a better tire, plus going from 255 to 275 on front) the difference in the reaction times of the suspension is noticeable.
mind you, the change reduced a significant amount of weight (probably 40+ lbs)
NightmareMoon
Losing weight in the wheel helps in theory, yes, but the question here is: is it noticeable to the driver.
I want fancy rotors. Someone buy a set for me.
bandit67
Mustang Addict
Lake Hartwell, SC
2015 GT, 2007 SPJ 302, 2019 Ranger
You won't FEEL the difference, nobody's butt-meter is that sensitive, but as you replace components to shave weight, you'll find the car handles better, is more responsive, times on the road course improve ever so slightly, etc. But you may only notice if you've repeated enough scenarios that you can compare the improvements to the baseline.
West TX GT
West TX GT
Ian
Kind of what I expected the answer to be. Pretty excited about it anyway.
Moddiction
Mooresville, NC
2016 Mustang GT PP
Losing 10lbs per wheel you should definitely feel. Even 3-5 lbs is normal to feel a difference. Usually more in the handling rather than acceleration though.
Chad11491
Roswell, GA
17 Lightning Blue GT Premium PP
My wheel setup weighs in right at 42lb less than the stock PP setup. Other than the suspension feeling way better and the wheels seeming to roll easier, I felt no difference whatsoever in speed or acceleration or whatever if that's what you mean. I do get about 1.5mpg more than I did on the stock wheels/tires, but that may be the PSS just being worlds better than the Pzeros, which they are in every way.
Coyote Red
Port Lavaca,Tx.
Alan
2016 5.0 Coyote Red
In my 2014 Cyclone I installed American Racing razors at 24 lbs a wheel with 18" 275/40/18 Bridgestone 760's and could feel the handling a little. The DSS shaft was really noticeable. Rotational mass matters.
Chameleon
Gold Sponsor
S550 INTERIOR DRESS UP
www.ebay.com
Yes, it makes a huge difference you will feel right away. Check my build thread.
