Extended studs or Wheel spacer adapters
Russell_Reed94
San Jose California USA
Russell
2019 Ford Mustang Ecoboost
Hi everyone I looked into it a bit but was wondering if anyone else could help me out. I just put some BC Racing coil overs on my 2019 mustang and dropped it 4 inches just for S&G to see how low I could go. I was thinking about raising it back up to just a 2 inch drop. The problem I am running into is that the wheels I have are barely rubbing on the inside with a 5mm spacer. The wheel set up I have is 19 X 10 +40 with 265/40/19 tires. I think I need at least a 15mm spacer but I don't think I will have enough room on the studs after a 15mm spacer. So I was thinking my two options could be to either put some extended studs or some wheel spacer adapters that secure down to the studs and have studs that are coming out of the spacer. I was wondering if anyone had any suggestions on which one of the two options would be better.
EFI
Masshole central
5.Br0
The right way to do it is with extended studs, especially on a situation like yours where you are lowered.
