Exhaust Diameter
Prodigal
OKC
2021 Mach 1
Adding Kooks 1.75” to 3” collector LTH. 3” mids with green cats. Do I need or should I use a 3” H pipe and 3” axle backs? If the entire system isn’t the larger diameter what difference does it make how much of it is? Only one 3” H pipe I am aware of, Corsa. Want to keep my AE capability. NA car for now.
GregO
Illinois
S550 GTPP
Off the cuff I believe your Mach1 system is 2.75" but I'm not 100% sure. You could measure your stock tube size to verify.
Figure out the OEM size and post back.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
1.75 is on the small side for a coyote. Most like the 1.875 Especially if you might add power later.
GregO
Illinois
S550 GTPP
To my surprise the OEM Coyote, VooDoo and Predator 4-2-1 header primaries are 44mm or about 1.73" diameter.
