GuiTaR FIXR
So…. My 2021 ecoboost will act afool sometimes when the fan kicks on when you are sitting at a stop light on idle.
it’s like its stalling out and then catches itself and then its fine. But it’s kinda sharp / violent when it happens
i’ve noticed it’s worse if it’s in gear.
Doesn't do it all the time either, but it seems to happen more just after you start the car.
two things i think about:
Battery dying? Im going to have that checked just in case.
Idle to low? It seems to be around 700.
The strange thing is when it stumbles, it acts EXACTLY like my rx-7 did during cold startup as the Haltech ECU trued to open the IAC valve to raise the idle until it warmed up and before it caught up with the fuel setting.
It would stumble and shake once or twice until the ECU caught up with the fuel demand from the opening valve and then it would snooty out.
but these cars don't have rotors or Idle Air Control valves….. do they? ;)
