Bull Run
Cross-posting it here for folks that don't visit the DIY section often:
2015-17 Mustang EBs and V6s got screwed on the line-lock, which came with the GTs. It's not that GTs came with a better ABS module; the hardware is the same but Ford installed a different firmware for EBs and V6s that prevented the activation of the line lock feature in the software. Now you can use FORScan and a cheap OBD II to USB interface (which is required for other methods anyways) to flash the firmware and enable the line lock, without having to replace the ABS module and hydraulic pump or buying an expensive UCDS tool.
https://www.mustang6g.com/forums/threads/line-lock-enabled-on-non-gt.96154/page-6#post-2591279
