Eibach Pro-Kit clunk noise
Gabess
PR
Gt 2015
Hi,
I just install the eibach pro kit and after the installation its been doing some cluncking noise at bumpstops and sometimes at potholes or irregular level roads.
We check everything and everything its tight. Any suggestions?
Thanks
Obsol3te
Hope Mills, NC
'15 GT PP
Make sure you tightened the nut at the top of the strut all the way.
Niz55
Us
17 GT350
Make sure the bottom of the spring is seated on the rubber piece.
I also used a pice of rubber tubing that cut in half and put it around the end of the spring
jabrax
Montgomery County PA
Jeff
2015 ruby red PP GT
Sounds like the top strut bolt. I had that issue, appeared tight. put just a few more turns on it and that did the trick. Check the torque spec on it
hamzah596
Hampton Roads Virginia
Hamza
2017 GT Premium
i have the same issue with this but with the rear driver side spring. when i have the car on an irregular surface it sounds like metal coming apart
