Burkey
Cool. Let’s see if we can get you sorted...@Burkey
This was a good read. I'm in Melbourne and the temps are probably not as high here.
I have been contemplating in a DIY install of the Edelbrock TVS2300 on my 17 GT (manual). I was thinking just the stage 1 install at this stage.
I was hoping that either yourself or someone else can help me out with some questions I have.
I've been doing a ton of research and feel comfortable with the install but just had some questions.
-Do all RHD cars require the trimming of the K-brace to fit the e-force? Obviously no mention of this on the Edelbrock manual. My car is on factory engine mounts.
-I presume the heater hoses wouldn't have been an issue for you if you hadn't modified them for the Whipple?
-Each seller/website seems to have different part #/SKU, with different descriptions and prices. I am not sure if the stage 1 kit comes with spark plugs and or injectors. I plan on changing out the plugs but wasn't sure if I could get away with the factory injectors.
-Some kits can be purchased with an Edelbrock tune. My car has aftermarket headers and cats and wasn't sure if the Edelbrock tune would work? Otherwise I was going to stick with Lund as I am currently tuned with them and are familiar with the process.
Sorry for all the questions. Hope someone can chime in.
Cheers.
Yes, the K-brace and cowl will need some trimming on all RHD vehicles. Basically the design is slightly different on our cars. They actually mentioned it in the instructions for my kit. If you need any tips on the easiest way to do it, let me know. Happy to help out.
As you guessed, the heater hoses wouldn’t have been an issue on a stock car, although I did have to slightly bend the RHS “neck” because it ran too close to the blower for my liking (false knock is shit to chase).
Based on some (most?) reports, I’d avoid the Eddy tune. Lund do a great job and I’d continue on that path if I were you. Personally, I’ve run both the Lund tune and PBD. Lund have the drivability perfected, PBD lacks a little finesse but delivers a little extra kick. I’ve also recently had PBD do me an E30 tune but haven’t had a chance to fully test it. That’s another story entirely.
Pick your pulley, pick your tuner, throw some NGK 6510s at it (make sure you gap them to 0.028”) and call it a day.
Unless things have changed, Lund would also want you to run either a BAP or a DW400 pump as well. I’d be asking the question for sure.
Just bear in mind that the 2300 isn’t just a smaller unit than the 2650. The rotor pack is less efficient and it won’t have the newer modular inlet (meaning the 2300 can’t breathe as hard). You’d want a decent discount on it when compared to its replacement. The gap isn’t huge for most of the rev range but the older blower does fall over a bit up top, where the 2650 doesn’t seem to. Or at least not to the same extent.
You probably wouldn’t really notice it, but it’s worth knowing.
Any more questions, let me know.
Cheers
