E85 consistency question.
Terminator2
Spring Hill Florida
David
2016 Mustang GT Premium
For anyone looking for a good brand, i suggest lucas oil fuel treatment. Its an upper cylinder lube. I buy the gallon container its a better deal. I also use lucas ethanol treatment it is good for those that use e85 but let some sit in the tank because its not a DD. It specifically states it works with e85 and one bottle treats 80 gallons. I run the lucas fuel lubricant because its the only one that i found that was polyisobutane free. For anyone wondering what that is, polyisobutane is the known ingredient that usually causes the gooish substance or blank junk.
That's the one I got.
wireeater
Virginia
wheelwell.com
Rich
Shadow Black 2025 Mustang DH HP
Wow, you must be babying it al the time or spending 95% of your time on the highway cuz you should be losing approximately 30% of your fuel economy with E85 from what I have read.
I don't live on a race track so ya, I'm not always into it. I just do cruising with some spirited pulls here and there. It could be lower I haven't actually calculated myself. Just using the onboard reader so I'm sure the calculations are off on that. I get like 200 miles out of a tank. I'll track it next time I fill up. Haven't been driving the car too much lately.
Jay159866
2015 GT 1966 Coupe
You should use 91-93 every couple fill ups even if for a 1/4 of a tank. Or run an upper cylinder lubricant instead. Been using e85 for over 7 years in my DD. I wouldn't suggest using e85 only long term without a lubricant. Nasty things could happen if you didnt.
So throw in a 1/4 of 93 when I fill up with E85? I'm just lowering the ethanol level at that point, right?
Is this what you're talking about? But in the gallon?
http://lucasoil.com/products/fuel-treatments/safeguard-ethanol-fuel-conditioner-with-stabilizers
And this, as the lubricant?
http://lucasoil.com/products/fuel-treatments/lucas-fuel-treatment
Jay159866
2015 GT 1966 Coupe
I agree, but he's also NA. His last post says 200 miles per tank which equals up to 12.5MPG. Which seems right for NA.
