Gee
I had searched up and down the forums here and didn't see much coverage of this product, but it's very popular on other well traveled forums. They've been around for a long time (90+ years experience) and make driveshafts for many racing bodies, including IHRA, NHRA and many NASCAR teams. They're manufactured with tight tolerances on balance and shaft runout, and they're balanced to 8000rpm and rated for 900HP.
That being said, I ordered a Dynotech through Brenspeed (excellent, FAST, customer service) who worked with Dynotech to get it made quickly as I was up against a deadline. Both Brenspeed and Dynotech came through in time and I got it installed yesterday. The DS itself weighed in at about 17.4lbs (sans bolts) vs stock 36.6lbs (sans bolts). The build quality was simply flawless and installation was very smooth and easy. I went for a test ride and it was smooth as glass, zero vibration up to 110mph. Of course, like any of the AL DS's out there, spin up due to less rotating mass feels a little quicker, snappier and the driver connection to the car feels more solid, as it should.
I know there's a lot of people installing aftermarket 1pc driveshafts who battle vibration and try clocking the DS, or just live with it, but Dynotech was a one shot in and absolutely flawless product. Couldn't be more pleased!
One recommendation if you purchase this driveshaft, get an 8mm & 10mm long ball hex bit socket. It'll make torquing the front and rear bolts a snap. One other thing not mentioned in the instructions, I put the two locating bolts for the pinion flange in the holes nearest the relief cutouts 180* apart (should have taken a picture, but forgot). The instructions say to simply put the two bolts in 180* apart, but they don't say which 2 holes. When looking at the pinion flange it made the most sense to use the holes near the relief slots. Probably not 100% necessary, but that's what I used and it worked out great.
Anyway, just wanted to send it out to the S550 specific crowd who might be looking to upgrade that rubbery, heavy stock 2-piece, make sure to include Dynotech as an excellent option!
