JJ@WMS
- Aug 22, 2014
- Woodbine MD
- 2015 EB Mustang
Since we own a Dynojet dyno and use it often I figured I would take the time to show and explain a few things about graphs.
First is smoothing.
Smoothing is a way to display the graph in a manner which is more appealing to the eye, it also gets rid of the rough jagged points of the dyno plot. Those jagged points come from the signal from a magnetic pickup attached to a drum where the drivetrain affects how smoothly the drum is rotated. If a vehicle has an out of round tire or an ignition miss then those things will severely affect how smooth the dyno plot is shown. There are also other factors that can affect the plot.
Standard Smoothing in the industry is set at 5 to show a standard smooth graph and to remove any anomalies from the graph/plot. Moving smoothing down to 1 will show more of those anomalies and usually give you a few more hp and tq along the way.
Above is our car completely stock with the SAE correction and smoothing at 5. SAE is the standard correction for temp and atmospheric conditions. 276hp/286tq are the numbers.
Above is the same dyno graph but this time the smoothing is set at 1, the correction factor is still SAE. Now its 281hp/290tq A 5hp/4tq gain from nothing other then changing the smoothing.
Now lets look at STD vs SAE correction factors. The following borrowed from LS1 tech;
Now here is our same stock car with STD numbers with the smoothing at 5;
283hp/293tq
Now with the same graph with the smoothing at 1;
288hp/296tq A 5hp/3tq gain just from changing the smoothing.
Lastly I'd like to make a short statment about tq spikes which will show great tq numbers. When you see those spikes look beyond that spike and further down the curve to see what the actual/average tq is. That will give you a better idea of the power that vehicle and/or modification is making.
Also keep in mind that dyno's calculate hp based off of a measured torque. HP is not measured, torque is and there is a calculation to determine hp based off of the tq the vehicle made over a given amount of time.
All of the above information is posted to show you the differences between different correction factors and different ways of showing the dyno plots in order for you to be a bit more knowledgeable when it comes to this subject.
I hope this information helps in some way and if I can be of any help dont hesitate to give me a call.
Thanks for your time,
JJ@WMS
First is smoothing.
The debate will rage on forever about which one is more accurate, I tend to lead with the SAE numbers but have used STD numbers before as well, its really up to the end user as to what numbers you feel represent the actual hp/tq of the vehicle.SAE:
"SAE (Society of Automotive Engineers), USA. Power is corrected to reference conditions of 29.23 InHg (99 kPa) of dry air and 77 F (25°C). This SAE standard requires a correction for friction torque.
STD:
STD is Another power correction standard determined by the SAE. Power is corrected to reference conditions of 29.92 InHg (103.3 kPa) of dry air and 60 F (15.5°C). Because the reference conditions include higher pressure and cooler air than the SAE standard, these corrected power numbers will always be about 4 % higher than the SAE power numbers. Friction torque is handled in the same way as in the SAE standard."
283hp/293tq
JJ@WMS
