Driveshaft
JimmyTwoTimes
New York
2015 GT Premium
Everybody knows about the high-speed driveshaft explosion issues with the 3.7 liter on the S197; is that fixed for this generation? If you remove the governor, will the driveshaft still explode?
Brent302
Springfield VA
2015 Mustang GT/PP
I believe the V6 is now 121 I think?
They possibly fixed it.
langweiler
lol, if not they will have all day some to fix with Mustangs running on our autobahn....i´m sure they have to improve a lot of things to make a Mustang safe and stable for selling to us. Otherwise the car will get a very bad reputation in hole europe. I heard the euro type will all have things like the performance package as standard ? Unfortunately the price is growing and growing for us....tax, bad € shit
Horse
SE USA
300 hp with 3 pedals
Hope they indeed have fixed it.......I am interested in V6
Ryan1112
Oviedo, FL
2015 Mustang GT PP
Unfortunately it does still have the 2 piece driveshaft. I'm not sure why they kept it. Must have to do with pinion angle or something.
JimmyTwoTimes
New York
2015 GT Premium
It doesn't make any difference to you, since it's a problem specific to the V6 model, which isn't being sold in Europe. Other models have two piece drive shafts that work just fine.
908ssp
Michigan
Alex
2015 GT/PP white
One reason they might be keeping the two piece drive shaft is for serious crashes. The new cars are designed to allow the motor to dive down under the floor in a front end crash. A one piece driveshaft will make that much more difficult, a two piece shaft folds up when impacted from the front.
908ssp
Michigan
Alex
2015 GT/PP white
Time for a CF one...
Up sounds like the way to go. I bet there will be a lot less complaints about the drive shaft. With the differential fixed semi rigidly to the monocque there is virtually no angle change between engine and the dif so if Ford installs it correctly it should always work correctly.
langweiler
I see rust at the mufflers, rust at the differential, rust at the driveshaft.
Are the mufflers no more in stainless steel ?
EXP Jawa
Rochester, NY
www.torsen.com
Rick
1999 Cobra Convertible, Electric Green
Ford uses 400-series stainless for their exhausts. It does turn brown and can some develop surface rust compared to 300-series grades, but my understanding is that it thermal cycles better. Aftermarket companies often use 300-series, like 304, because it shines up prettier. Ford has different priorities.
