This...these cars (well the PP and GT350's) have a TRACK mode, they expect you to use them on such.....:ford:Sure have. Radiator fans replaced, exhaust mid-pipe on driver side replaced, steering rack inspected and reset, oil cam phaser things on the passenger side of the engine replaced.
They won't touch my suspension because it's mostly replaced now and if I had a transmission issue, because I have an MGW shifter, I'd expect a fight.
Dealer isn't going to spend time checking "history" unless you pop your engine and that's not likely unless you have a terrible tune, go way too high in RPM and stay there on the limiter and blow out your oil pump gear.
Your biggest worry should be brake fluid and tires.
Gotcha - Thanks for the insights!Sure have. Radiator fans replaced, exhaust mid-pipe on driver side replaced, steering rack inspected and reset, oil cam phaser things on the passenger side of the engine replaced.
Ford gives info on this too:They even have a track prep guide with all sorts of setup info for the track.
Yes, and you get the fluid coolers that Ford tells us we should install for track use. Too bad that's such an ugly car with such poor ergonomics, the SS1 1LE would be a much better plug and play track car than even a PP2 Mustang.Yes, be careful what you say to the Ford dealer. I got tired of arguing with them, and traded my Mustang in for an ā18 Camaro SS. One look at the Mishimoto oil cooler and all hell broke loose with them.
Chevy covers HPDE on SS and above as long as you donāt mod. They even have a track prep guide with all sorts of setup info for the track.
Oooo... did you just insult my new car? addle:Yes, and you get the fluid coolers that Ford tells us we should install for track use. Too bad that's such an ugly car with such poor ergonomics, the SS1 1LE would be a much better plug and play track car than even a PP2 Mustang.
Don't blame you. I'd love to snatch up a 1LE. I was giving the PP-2 a consideration, but still MT82, no diff or trans coolers, oil cooler is a warmer after a while. Ug... if I had the cash flow to sell and buy again, I'd get the 1LE. Thankfully Steeda has made my car excellent, but I still have to slap on coolers and other BS that the competition offers stock. Ug!Oooo... did you just insult my new car? addle:
Ford told me to install the fluid coolers, then the dealer gave me hell for installing them. The Camaro has diff, M/T, and a big coolant to oil heat exchanger. It has 3 radiators. Plenty of cool for track day weekends for me. The Mustang would go into limp mode.
Look, it killed me to get rid of the Mustang. I loved that car. And Yes, I think the Mustangs are better looking.
But, I can tell you that after a few hours behind the wheel of the Camaro, you get use to the visibility issue. the seats are great, and I do like the looks.
The only two demerits I'll give it is lack of small item storage on the inside, and the small trunk.
Other than that, it is a nice place to be for the other 355 days I'm not on the track!
