Does a 2012 Boss 302 have a digital speedometer in the menu?
19gtaz
Arizona & South Dakota
2021 Mach 1 and 2013 Boss 302
And i don't mean by getting into the engineering mode, just in the normal menu.
Thanks.
From what I recall….
2012 B302 - the dash is an analog cluster only. It only has Speedo, Tach and in middle of those, the analog Fuel gauge and analog Coolant Temp gauge. The 2012 B302 was strictly all “Boss”, with no gauge cluster features.
2013 B302 - dash cluster has Analog Speedo/Tach and in between the center of those it has the small LCD display where the Driver could scroll through some options similar to the S550 dash cluster. Per the 2013 Dealer Brochure, 2013 is the first year for My Color and the Track Apps features:
Monitor on-track performance including g-forces, braking times and acceleration times in quarter-mile and 0–60 increments thanks to new Ford Track Apps
TM. It’s all conveniently located on a 4.2" LCD screen in the center of the all-new instrument panel.
There’s even a drag racing-inspired “Christmas tree” for accurate countdown starts. The Gauge Mode offers advanced features that provide the car’s air/fuel ratio, boost/vacuum, cylinder head temperature, and inlet air temperature.
Customize the interior lighting of your Mustang with available MyColor.® Choose from 7 base colors or create up to 125 custom colors for the gauge cluster’s background. Show your flying colors.
There’s no mention of a digital speedo or tach, or any other “monitor” via the 4.2” screen in a 2013 B302.
Boss1815
Massachusetts
David
2013 Boss 302, 2021 GT Premium
No digital speedo or tach on the 2013. No MyColor either. There are some digital gauges/readouts; CHT, oil temp, oil pressure, volts, A/F, intake temp on the 4.2" screen.
19gtaz
19gtaz
Thanks guys!
Linkster1666
AZ
Link
2019 Mustang GT Premium Orange Fury PP1 A10 401A 3:55
I had a 2012 V6 Premium, I assure you it had MyColor and MyKey.
I set a my key and it turned the key into a Valet Key. Needed two different keys, one master and you could turn one into a MyKey. I don't remember much about it other than it's a pain in the ass to get a master key once you screw up the only programmable key.
