DIY MyColor center cluster install
italianfroboy
Ankeny, Iowa
Griffin
2016 Ford Mustang
wait I’m lost now. High beam?
So put my old cluster back in and get its base ipc file. Plug in new cluster and write the base ipc to that cluster. While high beam is on or find its line of code and update it
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
LOL, sorry to confuse you.
When you get the new cluster programed with your as built, the high beam indicator will not work.
The easiest way it to enter your vin at the ford service website and download your as built file then use forscan to enter it.
I'll try to find the high beam indicator address, I thought I had it saved but I don't.
K4fxd
NKY
720-09-01XXXX**XXXXXX01 = Enabled** = DisabledThis shows the blue high beams icon when activated
italianfroboy
Ankeny, Iowa
Griffin
2016 Ford Mustang
Okay got it, I’ll uploaded as built data for my vin and update that line of code for high beams. Thank you! Hopefully this works!
italianfroboy
Ankeny, Iowa
Griffin
2016 Ford Mustang
I seen earlier post about the mileage, not being correct after the IPC odometer write. I found that adding plus four miles to the original mileage give you the closest correct mileage on the new cluster.
italianfroboy
Ankeny, Iowa
Griffin
2016 Ford Mustang
I tried that but it didn’t work sadly. Though putting the base model ipc got that error message to go away and I have a tach again.
K4fxd
NKY
Try 00 instead of 01
K4fxd
NKY
I never thought of trying that. Glad you got it working.
K4fxd
NKY
Program it with your cars as built info for the IPC.
italianfroboy
Ankeny, Iowa
Griffin
2016 Ford Mustang
So I installed the 2018 IPC into my 2016. My modes still work but for some reason the track mode doesn’t change the way the car shifts or the throttle response. I uploaded the old as built values and no change.
That line reads :
720-06-01: 6C7F-8000-18B1
tangguy
Virginia
Raul
2018 Mustang GT PP1
That line reads :
my 720-06-01 line reads - 7C6D-167B-9038. I have a 2018 GT PP1 with sync 3 upgrade and 2019 IPC
tangguy
Virginia
Raul
2018 Mustang GT PP1
I’ll try your IPC line then and see if that helps with anything tonight. Thanks.
I am sorry. I gave you my factory as-built config. The one that I am using for the drive modes is - 7C6D-167B-9840. please let me know if it worked for you.
