Diode Dynamics Foglights
Diode Dynamics
St. Louis, MO
www.diodedynamics.com
2015 Mustang EcoBoost
I don't really know to be honest. Nick says the stocks produce a better pattern.
I'm going to do a small comparison, and keep the winner. Cosmetically, I thin the TRS lights will look better, and match my 5000k osram's better. We shall see though.
Our Luxeon housings are identical to the TRS housings, as they are both produced by the exact same manufacture (Esuse). We did a side by side comparison on our 2015 with both installed and found that the factory Valeo's perform better
They are 5000-5,500K in color
Nick C.
mustang_guy
United States
it has an engine!
The Natural White option is 4000K / Pure White is 5000K / Cool white is 6000K
We also have Yellow 3000K
If you are located close to us here in St. Louis, I encourage you to come visit! I'd be happy to take you on a tour of our facility here
Thanks,
Nick C.
Yeah, im local. im in St Charles. i'll have to swing in some time. What about the luxeons? Are those available for the gt? I didn't see them when I saw all the the bulb options.
*edit* nvm I saw your post in pineros thread about the housings.
pinero61
Houma, La
'15 Ruby Red Base GT PP
Nick C.
May have some TRS fogs for sale soon. Lol.
Diode Dynamics
St. Louis, MO
Come visit us anyway! It's always nice to meet forum members in person :cheers:
Nick C.
pinero61
Houma, La
Nick C.
Go visit Jeremy, and get some good shots/videos of my heads with the new RGBWA boards. [emoji41]
Diode Dynamics
St. Louis, MO
You'll love em! The amber LEDs are definitely bright enough to be visible during the day
Nick C.
Brownw01
CT
Walter
15 EB PP Guard
Installed these today with the wifi controller (works through iPhone) (or android if you have).
Has pre programmed functions (strobe/ 7 color fade etc) you can adjust the speed at which it switches.
Also you can have it "flash" and change colors to music you put into it.
Supposed to be able to custom program as well.
I only played around with it for about 10 minutes as I had to go to work.
May end up connecting to a direct power source so they don't shut off after 15 min on ACC. In case at a show or what not and want them on.
Be sure to connect everything and make sure it all works correctly before you final install (tape and zip tie). You may need to flip connections around to get correct colors at same time.
Take off the cover in the very front of the car by the hood latch (like 7 or 8 push clips). Use a wire hanger to route the wires through. Super easy mod just takes time.
clevernickname
BC, Canada
2015 Magnetic Mustang GT, 2016 camaro ss (gfs), 2015 range rover sport, 2013 ford explorer, 2017 WRX
I don't see the option for the RGB bulbs. Were they removed?
clevernickname
BC, Canada
And sorry, I need this explained MUCH simpler to me
"Here in Canada they are H11 bulbs. The stock ones are yellowish looking and do not match with any other exterior lights. The Diode Dynamic H11 HP48 provides the similar amount of brightness without blinding the drivers in front of you." from a previous post another user said to try and help me
You guys are all talking about switchbacks and such. In my simple mind, this is how lights for cars work
Housing is the "case" of the fog/headlight. For example. H11 is the size for the fogs right? That means any H11 bulb (for fogs) can fit it? I doubt its this simple but I need this explained why I'm wrong lol.
And if it's right, since I'm in canada, is there no point buying the "glass universal foglights" (aside from better quality and bit brighter), and instead I could just buy the RGB bulbs from them?
Or do I need to buy their glass universal foglights to install the bulbs. Keeping in mind I'm in canada and they're my DRL I believe.
Voo Doo
Surrey BC
Ric
2019 BULLITT DHG
Yep x2 here!!
The Great Gazoo
Vancouver, Canada
2015 Mustang Silver GT/Auto
Any H11 bulb will fit for Canadian 2015's. I installed the HP48 last night in my car along with the switchbacks. The old bulbs came out and new ones popped in, no new housings are needed. They don't match the color temperature of the HIDs 100%, but much closer than the stock halogen fogs our cars come with.
If you guys want to hook up sometime and check out my car before ordering let me know. I am in Pitt Meadows.
clevernickname
BC, Canada
What are switchbacks lol.you order them separately?
The Great Gazoo
Vancouver, Canada
The switchbacks change the amber lights in the front of the car to white during normal operation. When the turn signal is applied, then it turns to flashing amber as required by laws. After the turn signal is cancelled, it returns to a white light. So they switch from white to amber and back again, hence the name. These are also a straight plug and play and don't need new housings. I prefer the modern look of white as a running light instead of amber.
Diode Dynamics has had some unfortunate quality issues with theirs but will get it straightened out. In the 24 hours I have had mine, I haven't had any problems. DD has a great return policy so if there are any issues I know they will take care of me. There are switchbacks available on eBay as well and other members report good luck with them so far. I'll stick to DD's though. The switchbacks are separate from the fog lights.
Watch the beginning of this video to see how they operate.
[ame]
Diode Dynamics
St. Louis, MO
The RGB fog lights (H11 size) are currently out of stock, but are expected to return within the next few weeks.
It's a direct bulb replacement for the H11 size, and the lights are controlled by remote (or smartphone app).
Nick C.
clevernickname
BC, Canada
Thanks everyone.
So basically US mustangs are LED but the lights can't be swapped out, so they need to buy a whole new housing.
Canadian mustangs are alraedy H11 led but ugly halogen color. So we can just buy H11 bulbs.
Is there a video for fog light installation? Someone said remove the belly pan. What is that...
