460Fred
Just throwing this out thereā¦What makes you think the A team, which is only one guy, was the one who changed your oil?I needed to get an oil consumption test back in March and I decided to drive about 40 minutes away to a dealership that had a performance service division. I felt that was the best option compared to my local dealership. They said they have one guy that works on the performance cars and that they needed to do an oil change before to start the test and mark the dipstick. I waited while they did the work and then I checked the dipstick to make sure oil was where it needed to be. It rained all the way home and when I pulled into my garage I instantly smelled oil. I knew at that point the under shield probably had oil all over and it did. Some was dripping out a little since they didnāt clean it up. I also noticed the texture valve cover where the oil fill is, had oil slopped over it, not even cleaned off from them spilling some. So much for going to a dealership that had special area for performance cars and they still canāt do the simple stuff correct. What an embarrassment on them.
I do work for dealerships all the time. Most of the new, untrained guys start in lube and tires. I could be completely wrong but if the dealership only has one performance guy, he didnāt change your oil.
Iām really careful when I do an oil change and still get some spills. The difference is I take the time to clean it up.
