Dash Cam/Lighter Power
The Demon
Brett
2022 Mach 1 N5809
I have a Garmin mini two dash cam and I pulled out the memory card to reformat it but I didn’t turn off the dash cam which I forgot to do. Now it doesn’t work anymore when I plug it into the cigarette lighter. I’m thinking that I blew a fuse and I found some diagrams but I can’t find out which fuse number it is. There is one called auxiliary body module but I don’t think that’s it. Any help would be appreciated. When I bring it into the house and plug it into my Mophie it works just fine.
gvn49
George
2020 Mustang, 2020 Explorer, 2007 FX4,1985 Mustang
Im sure you already checked the cig lighter outlet but just in case you forgot plug something else in and make sure it is still working, just a reminder in case you forgot. as you didn't state you did
The Demon
The Demon
Brett
2022 Mach 1 N5809
Actually I hadn’t done that because the dash cam worked when I brought it into the house and fired it up on a different power source. The power source in the CIG outlet came with my Garmin. So I did go out there and I plugged in my car vac and a couple other things and they all work just fine. But for some reason the camera will not even though it works on other power sources so this is really weird to me. Obviously it’s not the fuse because other things are working. Maybe I’ll try a different memory card because that one might be shot which makes it not work.
gvn49
George
cig works with other items, camera works with other power source, check "The power source in the CIG outlet came with my Garmin" usually when taking memory card out it messes up the card but sometime it can be reformatted.
joeyvaz
Saint Cloud FL
Joe
2021 Mustang GT
Does the cigarette lighter adapter that came with the Garmin have a built in fuse? I've seen some adapter that do have a built in fuse, so it could be that.
The Demon
The Demon
Brett
2022 Mach 1 N5809
I will check that but the adapter is working with all other devices. I’m down to the thought that it’s the memory card was corrupted. I’ve bought a new one and I’m gonna see if that works.
