sy1462
- Feb 23, 2017
- South Carolina
- 2015 Mustang GT
I have a Roush P2 with the Roush tune loaded. I ordered the SCT4 and custom VMP tune with IAT relocate. Today I installed the IAT relocate, loaded stock tune, then loaded the custom tune. Started and had a problem code P0315. I then did a crank relearn, which it took and cleared the code. Shut off, restarted and went out for a drive. Any more than about 10% throttle and the car goes into some kind of limp mode, throttle has no response at all and RPM's sit around 700. If I put it in park, shut it off, and restart it is ok again until exceeding approximately 10% throttle while in drive. It idles fine, shifts fine, no missing and seems to be ok until it just shuts down after giving it any more than minimum throttle.
I reloaded the stock tune a second time, then the custom tune a second time with the same result. The second time I did not get the P0315 error again but the car still shuts down with anything more than about 10% throttle. I only other thing I did was install the IAT relocate sensor/harness. I double checked all connections and reseated, all seem good.
I have a ticket in with VMP but wondering if anyone has had something similar I can fix this weekend?
