5.0yote
AKA Bananana & 3.7Cyclone
- Jul 18, 2015
- Mansfield, MA
- Website
- www.youtube.com
- Don
- 2016 Mustang Ecoboost Premium
- Vehicle Showcase
- 1
Considering the complexity of the harnesses, BCMs, IPC, and the can bus network its just better to try to get the harness and ECU from a similar speccd unit. You so not want to risk using a base setup on a premium car then find out your heated seats or cruise control etc stops working. Just easier to by pass that.Interior was super easy to do ! The harness all have different numbers but look very simular in colors and wire gauge all connectors were the same as well. However i have said in this thread before that u can most likey just swap the under hood harness and reprogram all modules and ur good ? Someone else can try that. Remember tho each model has a different harness, performance pack, gt, v6, base vs premium thats why i never posted harness part numbers .
Did I read you correctly did you have to replace all the Harnesses including front to rear? Or just the under hood stuff? I know there will be differences, you figure if you wanted to do it clean and purchase harnesses (even at dealer prices) for piece of mind, would you need to do so. I know the engine and trans are a give in along with the PCM. IF you had both wiring diagrams it would be easy enough to repin the existing if there were items out of place.
