Converting to power seats - Question
  • Thread starter Deleted member 35644
  • Start date
  • Watchers 2
Guest
Hey guys, bought a power seat track from a wrecking yard, and noticed an electrical connection on the bottom of it that I don't remember seeing on my non-power seats. What would plug into the red plug in these pictures?
BluePonyGT
Seattle, WA
Corey
2017 Grabber Blue GT Premium 6MT
Yep it's for that circuit board (about the size of an index card but a little wider) that controls a whole bunch of stuff for the seat: heating and cooling, and adjustment. My factory one failed on my passenger side, and I lost all heating/cooling until I replaced it. I can take a pic of my old one (yes I kept it like a crazy person) so you know what it looks like.
Guest
Confused... If the red plug does all that, what is this one for? The plug on the passenger like this one plugged into the car and the power adjustments worked. I was thinking the red plug must be for the power lumbar in the backrest, but it looks like I'm wrong.
BluePonyGT
Seattle, WA
Corey
Ah forgot to dig the old one out and take a pic.
That board actually has TWO connectors go to it. A short and a long.
Guest
It appears the driver seat track I bought has all the bills and whistles, while the car it's going into doesn't. Car has no switches for heated or cooled seats, and it doesn't look like it's going to be plug and play for the lumbar adjustment, even if I can get the backrest parts out of a wrecking yard seat. Just hoping the plugs that the car has will give the seat power to adjust the seat bottom cushion and forward/back.
Check the seat thread that was supplied above - quite a few M6G members have "upgraded" by swapping in power seats to a
vehicle that didn't have them.
Yes you do need to activate some stuff via Forscan, and yes you have to make sure you have the modules or harnesses - but other than that, it has been done.
Guest
Figured it out. Went and picked up a heated and cooled power driver's seat from a wrecking yard this morning. The red plug underneath my Ebay power seat track (no heat/cool) is for lumbar adjustment ( gray & green wire). Should just plug & play with connector from the heated/cooled back rest harness with the heating and cooling plug left unconnected, since there's nothing to connect it to on the new seat. Relieved.
BluePonyGT
Seattle, WA
Corey
I'll get pics of that board and put them up tonight. Sorry I keep forgetting...
Guest
You don't have to, I know which board you're talking about. The seat I bought over the weekend had one. My current seats nor the new seats have the boards. I'm not adding heating and cooling, I just wanted power adjustments, which are plug & play. I plugged it into the car and tested everything this weekend. I have full seat bottom and lumbar adjustment from existing wiring and plugs. Thanks for the help guys.
BluePonyGT
Seattle, WA
Corey
Cool!
