Condensation in FP Clear Tail lights
Angrey
Coral Gables
2016 GT350
It's an engineering problem. You can't seal the light housing completely, otherwise the wide temp range will see vacuum and pressure that could collapse or burst the housing. Over time with heat and venting, the moisture should evaporate away, although with clear lense the scale and solids deposits might be more noticeable under close observation (than red).
DougS550
Fishers, Indiana
Doug
Thanks… I think it’ll clear up, but I don’t think it should be happening in the first place…
Dont let anyone fool you. They leak because of "PAD" ( Poor Ass Design) which American Car manufactures have been doing since they put "Peanut Counters" in charge of R&D which meant their primary concern wasn't Quality or Reliability, but rather for Profits.
- Remove the tail lights
- Run a Hair Dryer over the back lens until the condensation is dried up
- Buy a tube of Silicone "ULTRA BLACK"
- Run a small bead around the perimeter of the two half shells where they come together
- Pull out the rubber grommets which the wires pass through
- Put a small amount of Clear Dielectric Grease around rubber grommets groove
- Re-install the rubber grommets
** Make sure their is a ( foam Rain Bead Seal) about a 1/4" piece of Rain Bead seal trim going around the the top half back of the tail Light so when water comes over the top of the light assembly, the water will not drain down behind the light, but rather around the top part of the light assembly.
Worked for me when I use to buy American cars for 50% always built up condensation.
Good Luck
HoosierDaddy
Randy
FP isnt OEM they are still considered aftermarket.
Which in this case is a distinction without a difference.
Ford Performance said:
These are the same as included in the Mustang Ice White Appearance and Stealth Packages
Linkster1666
AZ
Link
2019 Mustang GT Premium Orange Fury PP1 A10 401A 3:55
vdngo
Iowa
Van
2019 Ford Mustang GT Convertible
Mustangmatty
AZ
2020 GT/CS
Yeah, I caught my typo earlier, just waiting for someone to give me crap about it, lol…
Sorry, I had to. Wish I had a garage that big…..sooo many cars I’d wish to put in there.
