Compression test results surprised me
TheShit
Memphis TN
2021 Mustang GT Manual
So last weekend I installed a Meth Kit, but before I did that, I figured I would do I full tune up, and change out all my fluids and plugs, and do a compression test.
I watched a bunch of videos on youtube, and in their testing, most of the cyilnders are slighty different across the motor. My current motor has a new shortblock with only 10k miles, and the top of the motor was cleaned up really well before everything was installed back in my car, but it had 40k miles on it. So I knew my results should be good, but every cylinder tested 225psi except for one that tested 227. I thought my gauge was bad, so I ran to autozone and picked up a different one and I got the same results, except the one that was 227 is now 225psi.
Would a stock factory motor from Ford test that evenly?
I guess I was expecting some varied results across some of the cylinders
robvas
MI
2011 GT
It does sound odd that they were all exactly the same.
What procedure did you use, exactly, to test?
Wet, dry? Fuel pressure relieved? Throttle body open or closed?
Mike Pfeifer
Wesley Chapel, FL
2019 Ruby Red Mustang GT A10
I have had plenty of healthy motors test equally across all cylinders. Using two different gauges further confirms your results, sounds legit to me.
rolfe.oliver
St. Louis, MO
Oliver
1967 Mustang GT350 Tribute, 1971 Mustang Mach 1
Sounds like a healthy motor! The rule of thumb of multiplying 20x compression ratio would be roughly 240, so you all being around 225 is great!
