Code Reader for Suspension Fault
cwh19
Greensburg, PA
22 Mach 1
Hey All,
What code scanners will read suspension faults? Check engine light isn’t on, but suspension code is limiting to 80mph and no drive modes.
Thanks!
NGOT8R
Adrian
2019 Bullitt
What caused the issue and was the problem at the front or rear of the magneride system?
cwh19
cwh19
Greensburg, PA
22 Mach 1
At the front. It was actually a fault with the ride height sensor, passenger side.
Do you happen to know what caused the fault though? Mods to the Magneride such as swapping out stock suspension components for aftermarket?
cwh19
cwh19
Greensburg, PA
22 Mach 1
I have Penskes on my car and thought that the shock delete was going to be the issue. It was not.
My issue was actually the ride height sensor. I’m guessing I hit a rock or other road debris at exactly the right angle and it severed 2 of the 3 wires about 5” from the connector. Soldered it back and good to go.
