COBB Stage 0 - Truly Stock Performance?
AngelOreo
Delaware
JimmyG
2015 - Ecoboost Premium - 6mt - Deep Impact
I should have asked this sooner...
I want to get a truly stock baseline Dyno pull, but I recently loaded the COBB Stage 1 tune. Will Slot 5 give me a true Stock run or will I need to switch to Stage 0, and or unmarry.
Thank you in advance.
Jim
PS
I did search, not happy with the vague answers. The one did state "otherwise stock vehicle ", but I was not clear if there were other tweaks. I do run93 at all time, but Zero modifications.
WatchSquid
D/FW Texas
Jim
93 Reef Blue Mustang convertible
It's easy enough to put back on.
Just revert back to stock, do the dyno then reload your tune.
Contact Cobb directly and ask if there are other parameters changed in the v120 tune. I think (emphasis "THINK") that the slots are just changing the amount of boost.
AngelOreo
Delaware
JimmyG
I ended up doing stage 0. It took ~10 minutes to load initially and due to unfortunate timing, i dis not have the ten minutes to fully reload
kosa
New Jersey
2015 EcoBoost
Anyone used the Cobb stage 1 tune and checked for knock? I tried that tune last night on 3rd gear pull and it showed 2 counts of knock on Cobb unit. When I was monitoring cylinders 1-4 but I can't tell if that's just noise or real knock. Can anyone verify or is it my car?
LStillman
Virginia
M4dSc1ent1st
2015 Mustang EcoBoost Premium
A log would be preferable also what is your OAR at?
kosa
New Jersey
2015 EcoBoost
Well last night I just changed maps and hit the highway so OAR was def not -1.00 I get it to -1.00 tonight and hit it again and log it but as soon as I loaded the map I drove without hitting high boost it shower 1 on all cylinders I don't thing it's the plugs I put new ones in gapped to 026
