Clutch failed, need advice on new one
Kahboom
Kahboom
Cathedral City, CA
2015 Mustang GTPP, Recaros/2014 Explorer Sport 4X4
Bridgie
Raleigh, North Carolina
2015 GT fastback. PP, 50th trim, Black
Do it all....:headbang:
I’ve just gone through the whole process, when my Clutch disintegrated whilst on track.
Stock flywheel will not fully line up with the exedy face and it might be burnt up, the lightened flywheel will match the contact face exactly.
New throw out bearing, and slave... mine failed.
Replace all flywheel and pressure plate bolts for new.
Add braided clutch line and upgrade hose from reservoir to master connection.
See thread on here.
Also renewed fluids using Optimum Performance sync shift and Ate 200.
You are not the first to have a clutch go...
Kahboom
Kahboom
Kahboom
Cathedral City, CA
Where do I find the pressure plate and flywheel bolts?
Bridgie
mustang1
Dallas, TX
A.M. link indicates
"Torque Rating @ Rear Wheels: 734 ft-lbs
high clamp load pressure plate for crisp yet smooth engagement and great wear.
not sure if that will result in a heavier clutch peddle.
mustang1
Dallas, TX
I don't think you will get 734 lb ft out of a single disc, organic compound clutch. Particulary for $359. That A.M. link probably needs editing.
If you check exedy website, they offer an OEM replacement clutch. As well as their stage 1, enhanced organic compound to tolerate more heat, along with higher clamp loads, and that offers 498 lb ft. Stage 2 is Cerametallic, 587 lb ft.
Kahboom
Kahboom
Kahboom
Cathedral City, CA
Hmm so maybe stage 2 is the way to go.
yote41
pa
16 gt
You do not need a new flywheel for exedy as long as yours isnt toasted. Verified by am staff twice
Lonmon
Mid East US
2018 Mustang GT 10spd Base
I used that clutch on my 15 when my clutch exploded after only 7k miles. I used the Mach 500 and the LW flywheel. Inserting the dows in the flywheel is a bitch. I suggest if you get the flywheel from Exedy to take it to a machine shop to have the dows pressed in before attempting the install (if your doing it yourself). Other then that the clutch is great, with the factory spring in the pedal it feels like the stock clutch with the Steeda spring. Worked great for me up until I traded the car in on my 18 A10. LOL
raptorgabe
United States
i have that exact same clutch new in the box with a brand new slave cylinder . i was gonna install but im waiting on it . pm me if your interested just havnt posted it yet !
