Honestly, we have just answered the questions. We are not going back/forth. We were questioned when the car first got there and again this week, since they did not fix it yet, we had one of our techs call the other day and tell them how to check it even though its not a SC part.When you add a supercharger on your vehicle you will void your factory warranty as far as the engine goes, I took it to FORD twice and they told me to take back to the installer. This is the chance you take, Whipple supercharger and tune. Both parties have been communicating but trying to pinpoint did not work.
Some Ford dealers are good to work with and some are not. But you have to be the director of finding the issue if its at a dealership. The service writer has no idea and is typically trained to not be part of chasing things on modified vehicles. It needs to go to one of the qualified techs if its at a dealership and you need to find out what they would do if it was stock with the same issue. It's possible it's a Ford issue as I've said they've had some Phaser issues. If it's a factory issue that the SC didn't cause, they can't legally void the warranty. They could charge for SC removal/install but let's say the filter for the oil control is clogged, the SC didn't allow debris in there. If a cam lobe is bad, the SC didn't fail that. Not stating any of these are the exact issue, but it takes a little extra effort to get this diagnosed and fixed.
So again, as we've said before, it has to be diagnosed as a stock engine as the wiring, sensors, control, etc are all stock in this area. Only the cam position is changed in the calibration. In fact we have extra logic in there to help for cam misalignment as they can vary in position. But if its outside that window it will set a code, same as stock.
