Dfeeds
- Sep 30, 2018
- Illinois, US
- Dan
- 1997 Mustang (5.0 HO swap), 2019 Mustang GT PP1
I completely understand a car having history. Parting with my old Mustang was one of the hardest things I ever did. I almost had it stolen from me and stabbed someone with the keys getting away (same key is dangling from my rear view mirror).
However, this road you're going down is going to be a huge PITA. My old Mustang (97 sn95) started it's life as a v6 and I swapped in a 5.0 from a junked 95 GT. The manual transmission bolted right up with a bellhousing swap but that was the easiest part. The engine, even with a proper wiring harness, didn't match the codes for the dashboard harness which triggered the theft prevention and caused a slew of problems that forced me to rewire the fuel pump and yank the theft light bulb. The new harness didn't have the passenger side turn signal wiring (for whatever reason) so I had to splice. The high fan speed didn't work so that involved soldering a switch into the ccrm. I never got the dash tachometer to work. And after it was all said and done I always had problems here and there because none of the damn sensors wanted to stay working before every. single. one was replaced. Then the brake lines split and.... anyways.
Your issues will obviously not be anything like mine but the point is that you could have just as many headaches. If you have the time, money, and unparalleled perseverance, then go for it. Mine obviously gave out after a rod bearing seized up because I'm in a 2019 GT.
If you're committed, the best starting advice I can give is to make damn sure you have everything, and I mean everything, before you begin. I say this because, even being thorough, you'll find stuff you're missing part way through and that's the sort of hold up that make you want to stick your foot up someone's rear. So minimizing downtime should be your biggest priority. Besides, these new engines are so sensor driven that you can't afford to be missing anything. Beyond that, all I can do is wish you luck!
