20ducks
- Jun 7, 2020
- Originally South Side Chicago
- Greg G.
- 2020 Mustang GT Premium Convertible Rapid Red
- Vehicle Showcase
- 1
The PH of dawn dishwashing detergent is in the neutral range of 7-8 and won't hurt a clear coat. It's also not abrasive and won't scratch your clear coat. You're likely to scratch things more through normal washing from rubbing in dirt and contaminants. I don't think that anyone is talking about using it all the time, simply to clean off the surface including thin wax coatings to get down to the clear coat.... to further clean and then polish it out.
People are talking about spraying Iron off to remove the iron particles from brake dust as part of the correction process for the paint ... a far harsher chemical than dawn dish soap.
Brought to you by The Last Coat comes Iron Off, our heavy-duty professional-strength iron remover and wheel cleaner which can also be used to decontaminate painted surfaces, glass, and more. (Do not use on raw aluminum, Iron Off could etch it.)
Dawn mixed with water isn't going to etch metals or dry out rubber seals from a wash. While there may be specially marketed products for the process, it doesn't necessarily mean that anything otherwise is bad.
