Centri catch can options
vaeevictiss
VA
Sean
2021 Mustang GT Premium PP1
So ill be installing an ESS centri and I'm looking at a new catch can since mine doesn't have a check valve. I got it narrowed down to two and I'm wondering what the extra couple hundred dollars really gets me on the one.
This one is close to the JLT one I have now but with a check valve. This one is $175 with a check valve.
https://www.uprproducts.com/18-22-mustang-gt-plug-n-play-sc-oil-catch-can-separator/
This is the one a lot of people are using and I'm really just curious what makes this one so much better . Its $369 unless you get the better check valves then its $469. https://www.uprproducts.com/11-23-m...ged-dual-valve-oil-catch-can-css-plug-n-play/
There's also one with a breather or just getting a breather for the oil fill hole. I know some people don't run any catch can so I'm just curious what the different options get you.
Proshop
Billy
2021 Ford Mustang GT
Had that UPR on for 8 months with out any issues. Have since switched to vent to atmosphere UPR.
vaeevictiss
vaeevictiss
VA
Sean
Which one? Seems the more expensive one works under boost as well. Is that needed?
Proshop
Billy
I ran the UPR that you linked to in your original post first and then switched to the vent to atmosphere because you can’t run the one you linked above with a velocity stack turbo guard.
vaeevictiss
vaeevictiss
VA
Sean
I linked two but I'm guessing you meant the second one. I did read that but I don't plan to run it without the ess intake and filter.
Proshop
Billy
Hahaha sorry had an elderly moment there 🤦‍♂️! When you mentioned jlt I thought it was a link to a jlt one and didn’t even click on it. Yes I ran the second UPR link you sent. It will get the job done perfectly!!
vaeevictiss
vaeevictiss
VA
Sean
I guess what I'm asking, is if that one is necessary. Seems like the main thing it does is also work under boost where as the cheaper one only will work with vacuum. Does it need to work under boost? I've had two turbo cars I put simple catch cans on and it worked fine and collected oil. Even the ones ford makes for the ecoboost engines don't work under boost.
Proshop
Billy
Is it necessary? No, I’m sure you can run just a simple catch can system just make sure you have check valves were they are needed. I will say the second UPR system is very nice, works well and comes with all the necessary items for proper use.
cbrtrx
tampa fl
2016 mustang gt
On boosted applications I always run a catch can vented to atmosphere. Even the best catch cans can not 100 percent eliminate oil contamination, you'd also have to worry about the check valves under boost. If you're not opposed to an open system then that is the way to go for boost.
beefcake
Bethel
2018 Ford Mustang
this is the one we recommend on that kit if you have your intake tube.
https://www.beefcakeracing.com/5030-146-1-css/
if you want to do a breather tank / or you remove your tube and filter only, this is the one we do
https://www.beefcakeracing.com/5029-221/
horsepower addiction
Arizona
Nate
s550
On a boosted application, the catch can should only be there to keep from making an oily mess. some people with vent to atmospheric spit a lot or oil out the breather. the catch can should only be there to keep that from happening. you should vent to atmosphere with or without a catch can on a boosted application. no check valve.
Arizona
Nate
s550
I can’t think of any benefits to the catch can other than if your engine spits oil out of the breather.
beefcake
Bethel
2018 Ford Mustang
these cars don't come with any breathers.
the catch can is to keep oil out of the intake and from diluting your fuel quality causing knock
