Can I run a Centri without BAP?
smokinzx14r
ST Petersburg FL
Lee
2015 GT A6 3.55 Gears ..
I was out of pump with a 3.70 pulley with ID1000 injectors @ 6900 RPMs 604 HP on 93 pump gas .. I added a plug and play BAP and it was safe with my 3.50 pulley @ 7200 ... After that went E85 and sold the BAP and went with a Si Li fuel system ..
MikeyPee
dissmember
Commiefornia
2015 IS Premium GT w/PP
If you install it yourself, which you should cause it is soo easy. Make sure you give it a very good ground. Sand paper and a drilled and tapped hole for a bolt to hold it down to the frame/body. I've personally done it and have seen too many not give their boostapump a good ground and 1: not get the benefit 2. probably kill their pump from the varying voltage caused by the bad ground.
THIS...
Who knows if my BAP was doing anything, when I had it installed. I re-used the BAP ground for my FORE system (FPDM), and I traced an open to the ground point. Stripped some paint and grounded it directly to the car frame, and everything is perfect now
beefcake
Bethel
2018 Ford Mustang
stang17
Wilkes Barre, PA
2017 GT Premium PP
I'm currently running the Whipple Stage 2 Gen 2 kit with 3.625 pulley on 93 octane. 78lb injectors on stock pump without BAP provided no problems running 12-13psi. Data logs were spot on and made 786 whp on DYNAPACKs.
I posted a copy of the log file from HP Tuners over here if you wanted to check it out.
https://www.mustang6g.com/forums/showthread.php?t=103976&page=2
