Catless DP and emission test
JungleG1337
MD
2015 Ecoboost
Have anyone here run catless DP and Bama tune when getting emission test?
Grimace427
NoVA
2011 Mustang 5.0
If you are catless you need to have the rear O2 sensor switched off to prevent a check engine light. This is an automatic emissions failure. You can use a non-fouler to trick the sensor and a tune with the sensor on, but both options are technically illegal. If all you are doing is installing a downpipe you should be able to swap back to the stock cat fairly easily(not like headers on a Coyote).
Renner
Huntley, IL
2016 GT SOLD-2015 Ecoboost SOLD
taking the CEL off doesn't do anything...you will still fail emissions. Downpipe is 45 min job...just switch it back
JungleG1337
JungleG1337
MD
2015 Ecoboost
i see. i guess it is safe to go with catted. thanks guys.
Grimace427
NoVA
2011 Mustang 5.0
Aftermarket catted would put you in the same situation. Only stock cats works with an emission-friendly tune. Otherwise you would need to trick the O2 sensor with a non-fouler just like if you were catless.
JungleG1337
JungleG1337
MD
2015 Ecoboost
hmm i guess swapping when the time come is the only way
EcoSwag1990
West Chester, PA
2016 Triple Yellow GT
But at least a catted won't smell like ass
Grimace427
NoVA
2011 Mustang 5.0
Catted smells better, but still not perfect. Aftermarket high-flow cats are metallic and just can't offer the same efficiency as OEM ceramic 3-way cats.
