Caster Camber Plate Install
nastang87xx
San Diego, CA
2016 GT350 Track Pack
Hey dudes, anything I should know about when installing caster camber plates with the MagneRide struts? I'm sure there's something that needs to be unplugged from the strut. Should I pull the battery or any other precautions so I don't screw something up?
Tomster
Beware of idiots
Tom
I didn't pull the battery. Yes there are a few connections. Just take your time and take cell phone pics of everything you undo. You need a spring compression tool unless you plan to have a shop do that part of it. I hope you got the vorshlag plates. To go through all tbat trouble, I wouldnt want anything else. Have fun.
nastang87xx
nastang87xx
San Diego, CA
If you're doing lowering springs, I would recommend doing all of that at the same time.
ABSOLUTELY NOT lol. It's already low enough for me. I have speed bumps and stuff I need to get over on a regular basis.
nastang87xx
nastang87xx
San Diego, CA
Yeah I have a friend with spring compressors. I took a look at Vorshlag's post and it looks pretty straight forward per usual regarding suspension. Just time. Thanks!
xXANCHORMONXx
SF CA
I've done springs on a few s550s including my gt350
Spring compressor is not needed on the fronts.
I can easily push down on the strut, these spring rates are very low
