nastang87xx
Close, my man. Materials have 3 fundamental properties: strength, toughness, durability.It's likely a combination of both; adequate stiffness costs money. A simple CF tube likely isn't going to cut it. It has to have lots of cross-lattice layers of high quality CF which is expensive. One of the advantages of CF is that it does flex a bit: it's strong, but not super stiff. Remember, stiffness and strength aren't the same.
Strength is a material's resistance to being manipulated out of its native shape. A good example would be high carbon steel. A bad example would be wood, tin, or aluminum.
Toughness is a material's ability to shrug off breaking or cracking while maintaining its shape. Shock resistance basically. Carbon fiber is a good example as is some woods. A bad example would be glass or raw tungsten.
Durability is a material's wear resistance, if you will. A prime example would be tungsten alloys, glass, or diamond. It doesn't scratch or wear down easily. A bad example would be soft steels or basic plastics.
In general, most materials excel in 2 of these and are a bit lacking in the third, depending on application. Basically, take 100 points and divide them up into these three categories. Enjoy.
Moving along now...
![0701 :thumbsup: :thumbsup:](/forums/styles/smilies/0701.gif)
