Car moves side to side at 120+
taccone805
ventura
chris
2016 s550
Car has a almost wobble to it above 120 I have the performance pack 1.5 drop in the rear 1.25 in the front tires in rear 285/4019 frOnts 255/40r19 it’s almost like something is fighting the tires
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
What's your alignment settings?
moffetts
San Mateo CA
Black Whippled 2015 GT PP
Like bmac said, confirm your alignment is good and also check that your hubs/bearings are nice and tight. I have experienced that weird shimmying and it was a combination of both.
ronemca
ON Cda
Ron
2016 P/EB w PP
Verify tire pressure and hub-wheel interface (plus lug nut torque) on all four corners as well.
BmacIL
Enginerd
Naperville, IL
I’ll have it checked and get back to you thanks
OK. As you mod and as you take a car to the performance envelope, factory alignment "green" windows are no longer good enough. Things must be very close, particularly with toe left and right, like 0.01 deg off, 0.02 tops.
ronemca
ON Cda
Ron
2016 P/EB w PP
Another possibility that would directly explain the original complaint is excessive alcohol levels in the organic control system.
Just sayin'.
F1scamp
Upstate Ny
16 Mustang GT
Check your rear axle nut torque. Sounds weird, but mine developed and similar side to side wobble at higher speed and acceleration. One of the axle nuts had loosened a couple turns. Tightened it up and it went away.
Roadway 5.0
Strassejager
New York - USA
2016GT PP 6MT
Just sayin'.
:lol:
OP, I suggest checking your alignment and tire pressures first. Too low of pressures, and the ensuing sidewall flex, might cause your problem at those high speeds. If you did not get an alignment following your spring install, or had an alignment improperly done, this will surely cause issues.
aleccolin
VA
www.CarClubVT.com
Colin
2016 GT PP
Lowering without alignment usually means toe-out which is great for low speed cornering (autocross) but crap for high speed stability.
