Car is going nuts!!!!
2015-5.0Guy
st louis
earl
mustang 2015 5.0
Hi, i switched to the 2018 intake manifold on my 2015 5.0 and i have been having problems every since. If i push up on the evap housing connection thingy, the car shuts off. The car also makes tick noises under the hood. And it has a spray noise going on like some fluid is misting somewhere (not found if that is the case). I noticed the car is now losing coolant slowly. I look under the hood and the seems to be coolant all over the engine. The cap was properly screwed. I looked around for the source, but cant seem to find anything. Any thoughts? I had a mechanic hard wire the IM in. I then had his work double checked by a mustang performance shop and they confirmed that there is no issue with his install despite the p2005 and p2006 code i have. My guess is these codes are related to him hard wiring? However, this is a seperate issue that i dont think is related to the coolant issue- i just want to give some context incase it may help solve this issue. My main issue is where the coolant is coming from and what is this noise?
blankman
CNY
2023 GT
Have you thought about using a uv dye? They make kits that come with a light or glasses so you can see where the dyed coolant is leaking from or what its possibly hitting to splash on things.
