Calling a IDS guru
Aussie-up-north
Canada
Lucas
2015 GT Vert
Any IDS gurus here?
working on something.
The fpdm on the second gen mustangs…. anyone seen a adjustment in the key on fuel pump prime time?
bankyf
Fredericksburg, Virginia
2022 GT500 CFTP
I don't think you'll find that in IDS as a pre-defined adjustable parameter. Perhaps as built data, but I doubt that as well as I would assume that is a PCM function. I don't recall seeing it in HPTuners either, but they might be willing to add that parameter if you emailed support. You may need to look into some type of time delay relay.
I had been meaning to ask you if the Fuelab pumps had check valves, but I suspect you just answered that question.
Aussie-up-north
Canada
Lucas
2015 GT Vert
Nope they have good check valves. Just have to factor in “brushless” = more technology. With that if I had 1 more second fuel prime it will be better. But with that don’t run -12 feeds :p. -10 would be best
