Voo Doo
Steeda front K member.... what do you think you need?? I’m installing the Steeda G track front cross brace. The Cross brace 4 point extreme is really not req’d! Try the 2 point cross point 1st!! Then see!!!So far on my 2019 Bullitt I have installed:
JLT Passenger Side Oil Separator
Steeda Air Filter
Steeda Jacking Rails
Steeda Wheel Spacers - 1" Front and 20mm Rear
Around the end of July I'm installing:
Steeda H Pipe
Steeda Front K Member
Steeda Transmission Mount Insert
Steeda Differential Mount Inserts
Steeda Stop The Hop Enthusiast Kit
Steed Rear Lower Control Arm Inserts.
Can't wait!
See this if you are a corner carver only!, https://www.steeda.com/steeda-s550-ultralite-2-point-g-trac-brace-555-5533.html
I lowered my BULLIT Magnaride... (Steeda progerssive lowering springs) I have the adjustable BULLITT Steeda front/rear sway bar End links! Add 1/2” to the front pair and leave the rear as stock! Either way...you can’t go wrong with steeda!!
I started modding before I finished the paperwork. D shaped steering wheel, Eibach springs and sways, Borla mid pipe and axle back exhaust, MGW shifter, floor and cargo mats, run flat tires, and .......... Whipple blower ! Some people like drugs. Me, I'll take 700 + HP anyday.
