mnmike59
- Apr 5, 2016
- 2 hours South of BIR
- 2016 Mustang GT PP
Mike, here's a few pictures of how I routed my hoses.
After inspecting my hoses, I do see some slight pinching of the hose on the driver side from the sway bar but most of my rubbing comes from the steering rack boot.
A couple things that I noticed from your original setup:
- I see you are running an aftermarket sway bar (BMR?) with the stock endlinks. If you add some adjustable endlinks you can lengthen them so the bar ends are parallel to the ground - this will give your hoses more clearance.
- Also, its tough to tell from the photo but it appears that driver side hose is pretty stretched out which will also cause issues. Make sure you have plenty of slack in the hose to allow full range lock-to-lock.
Good luck with your track day!
That's Great! I was curious why you had sooo much more clearance between the Sway bar and frame. After tomorrow, new end links are first on my list.
Thank you!
BTW, The rotors your sporting on on my short list as well. The ones I have from Optimim performance are an awesome low cost way for weekend warrior track guy. I'm looking to get a little more serious next year.
