Boost hand starts shaking close to 10lbs
robmustang201528
15 mustang gt302blown
LA
15pp
My boost hand is shaking when I get to 10lbs should I be concerned?
96gt4.6
Kansas
2017 GT Premium/A6, 2020 Explorer ST
I have to know, what is the setup on this car? Sounds great!
ahl395
Allan
It doesnt look like its shaking to me.
I cant remember but I believe you're wastegated it might just be the flutter of the wastegate. Try adjusting the sensitivity setting on your boost controller if you have one.
robmustang201528
LA
15pp
Vortech jt trim v7
8 rib pulley upgrade
Id1000 injectors
JLT intake for vortech kit
VMP boost a pump
Beefcake torque booster kit (turbosmart hypergate45 wastegate)
Turbosmart e-boost boost controller
robmustang201528
LA
15pp
I haven't passed 6500 rpms yet. Lund looked over the logs said it was ok. Going to get it retuned just to double check everything
robmustang201528
LA
15pp
Vortech jt trim v7
Id1000 injectors
VMP boost a pump
NO CATS!!!!! American racing headers, x pipe and borla s mufflers
ahl395
Allan
Adjust the sensitivity setting on the boost controller if your boost is fluctuating up and down. Read the manual it will explain it
3beeps
www.instagram.com
'17 GT
I'm not sure if the boost is fluctuating or if the gauge is just vibrating.
Ruiner46
Colorado
2016 CO GT PP
3rd motor and already going 140 on the highway with the same tune.... ha ha. Look, do yourself a favor and get a setup to monitor the knock PID while you're driving. This way, if you get some bad gas or something you will see it as an increase in knock retard and you can take it easy until you get better gas. If you monitor knock all the time, you'll get a feel for how happy your tune is over a variety of driving conditions. I wouldn't trust just a single log that someone said is ok. Things change when it's hot, or cold, or when the gas quality varies. Simplest way is an Android phone with the Torque app, and a bluetooth OBD2 adapter. If you go the phone app route, make sure you get an app that can use a custom PID because the knock PID isn't supported on any app that I know of. I think an Ngauge will also do this, but I don't have any experience with that. Torque will allow custom PIDs.
robmustang201528
LA
15pp
Yeah I know. I'm pushing my luck. Gonna have it dyno tuned and have him adjust my boost controller as he tunes the car. What I've should've done in the first place. The guys at Lund are good but they can't make any adjustments to my boost controller since their not here while the car is getting tuned. 11 12 lbs is all I want. Need to 700hp plus on that dyno sheet
