BMR Suspension's New S550 Rear Upper SHOCK MOUNTS: SM760 - Design Finalized!
Discussion in 'Suspension, Brakes & Chassis' started by BMR Tech, Dec 4, 2018.
  1. Roh92cp
    Roh92cp Well-Known Member
    First Name:
    Shawn
    Vehicle(s):
    OW GTPP Whipple
    Jun 27, 2015
    Fort Kent Maine
    2,823
    1,082
    Rating:
    100%
    4   0   0
    Will these offer more clearance for wider wheels like the the Steeda's do?
    Martinnfb likes this.
  2. Martinnfb
    Martinnfb Well-Known Member
    First Name:
    Martin
    Vehicle(s):
    2015 GT, PP,
    Dec 27, 2017
    Calgary , AB , CANADA
    312
    313
    0   0   0
    Brilliant idea and execution !
  3. DMassey
    DMassey Active Member
    Vehicle(s):
    Jun 6, 2014
    Boone Co. WV
    39
    I will order up a set of these the day they are available. I just installed SP080 springs and a slew of other BMR parts on my 2018. I'm assuming with these mounts we won't have to trim our rear bump stops since it will be raised when it's mounted?
  4. udcvsean
    udcvsean Well-Known Member
    First Name:
    Sean
    Vehicle(s):
    2019 Mustang GT
    Apr 3, 2018
    Bay Area, CA
    107
    Occupation:
    Construction
    Rating:
    100%
    1   0   0
    I’m currently waiting on my 2019 Mustang GT PP w/ Magneride replacement for my 2017 lemon (shortblock replaced for ticking/scoring in three cylinders). ETA is early February. I was planning to install the SPH765 springs along with CB005 and FP knuckle to toe link bearing. Should I wait until BMR releases the shock mount design for Magneride and install them all at once then?
  5. BmacIL
    BmacIL Enginerd
    Vehicle(s):
    2015 Guard GT Base, M/T
    Sep 21, 2014
    Naperville, IL
    14,725
    8,576
    Garage Profiles:
    Rating:
    100%
    3   0   0
    The mounts are easy to do anytime after and do not alter alignment or anything of the sort. You could wait, but no reason to really.
    udcvsean likes this.
  6. Biggsy
    Biggsy Well-Known Member
    First Name:
    Warren
    Vehicle(s):
    '17 GT PP, '02 4Runner
    May 3, 2018
    MD
    655
    253
    Rating:
    100%
    4   0   0
    still wanting to know this
  7. BmacIL
    BmacIL Enginerd
    Vehicle(s):
    Sep 21, 2014
    Naperville, IL
    14,725
    8,576
    Garage Profiles:
    Rating:
    100%
    3   0   0
    The torque will be such that the joint stretch will counteract loosening. If it's a nylock nut (as I believe it is), that will prevent loosening, also.
    Biggsy likes this.
  8. jperls
    jperls Well-Known Member
    First Name:
    Jason
    Vehicle(s):
    2015 Magnetic Metallic V6, 1970 mustang convertible
    Nov 22, 2015
    Thousand Oaks
    695
    270
    Occupation:
    Accountant
    Rating:
    100%
    2   0   0
    Subscribed...have Steeda's rear shock mounts on...however, I like this design since it includes a point of articulation for the rear shocks...however, I am unsure if I really need this as I am only lowered 1/2in in the back with BMR springs. And with just over 71k miles on the car now...really wondering if I should be putting more money into the car...it already handles incredibly well with the setup I have...thoughts @BMR Tech?
  9. BmacIL
    BmacIL Enginerd
    Vehicle(s):
    Sep 21, 2014
    Naperville, IL
    14,725
    8,576
    Garage Profiles:
    Rating:
    100%
    3   0   0
    Getting the shock travel back and more is a good thing for mounting durability and ride. The stock car arguably doesn't have enough travel before hitting the stops, as it is on them regularly in normal ride events, not just big bumps.
  10. NorthernMuscle
    NorthernMuscle Active Member
    Vehicle(s):
    2015 GT
    Oct 11, 2017
    Ontario
    42
    Agreed. I have Steeda rear mounts, Pro-Action Shocks & Struts, and BMR SP083 springs as part of my build, and feel that lack of overall shock travel is most lacking part about this setup by far. I found the Eibach bump stops work perfectly for the transition from travel to bottom, so I never have any harshness issues in the travel... just a lack of it when driving aggressively, and is what erodes my confidence the most when pushing it at any real speeds. It's made me contemplate the next level of aftermarket suspension on my next (4th) Mustang, or perhaps just go to something completely different, that's more purpose built with higher end OEM suspension :(
    I was under the impression the travel on Steeda's Pro-Actions was less than stock. Does anyone know if this is accurate, and if yes, would swapping my setup over to these BMR mounts create any issues from the rear shock being "asked for" more travel than they were designed for? Thanks!
  11. BmacIL
    BmacIL Enginerd
    Vehicle(s):
    Sep 21, 2014
    Naperville, IL
    14,725
    8,576
    Garage Profiles:
    Rating:
    100%
    3   0   0
    Provided that you still have to compress the shock some at full suspension droop during installation, it should not create any issue. If the shock limits control arm travel with the raised height mount, that would not be good.
  12. Bagration
    Bagration Well-Known Member
    First Name:
    Paul
    Vehicle(s):
    2015 GT delivered 8 May 17
    Jun 11, 2016
    Canberra Australia
    323
    301
    0   0   0
    Hi there
    Will this work with the Vogtland rear damper and spring? from their coilover kit?
  13. ChitownStang
    ChitownStang Well-Known Member
    Vehicle(s):
    2015 Mustang GT Premium
    Mar 9, 2015
    Chicago, North Shore
    813
    209
    Garage Profiles:
    Rating:
    100%
    1   0   0
    I wonder if this design will be less clunky/noisy on bumps?
    Volstang likes this.
  14. BmacIL
    BmacIL Enginerd
    Vehicle(s):
    Sep 21, 2014
    Naperville, IL
    14,725
    8,576
    Garage Profiles:
    Rating:
    100%
    3   0   0
    With the o-rings installed you should expect no noise.
  15. udcvsean
    First Name:
    Sean
    Vehicle(s):
    2019 Mustang GT
    Apr 3, 2018
    Bay Area, CA
    107
    Occupation:
    Construction
    Rating:
    100%
    1   0   0
    Any ETA on release for Magneride-equipped Mustangs?
    lil'Zeus likes this.
Loading...
Share This Page
